The better of two evils... (loctite fix question)
wun911
Re: The better of two evils... (loctite fix question)
Postby wun911 » Fri Sep 14, 2018 3:19 pm
I've used acetone to remove epoxy.... you pour the acetone into a rag and wrap it around the crank nose, just keep on applying as it evaporates very quickly. This way you don't have to heat anything.
every ounce counts
