6 speed gearbox oil
Nevyn72
Re: 6 speed gearbox oil
Postby Nevyn72 » Thu Jun 28, 2018 5:27 pm
Bottom line, the 6-speed will always have a difficult 1-2 shift, especially when cold.
They still make and use the same box, now in the Toyota 86/Subaru BRZ, and it has exactly the same problem..... :|
Replacing the shifter bush with a new factory / Derlin / complete SSK often helps somewhat.
Also using the right fluid (USE ONLY GL-4 KIDS!!), normally Redline MT-90 is recommended, In the USA they love their 'unicorn juice' Ford fluid but the only way to get the real thing in Australia is to import it yourself.
I've heard of people using Nulon before but never with good results......
(Note there are mixed reviews in comparisons between the Redline & Ford products on the forums in the US)
So, replace the bush and/or shifter, use the correct fluid, and just be gentle until the box has warmed up fully for the best shift you can get! :mrgreen:
Postby bruce » Thu Jun 28, 2018 9:06 pm
Just don't expect miracles from an oil change.
My Nissan box is clunky from 1st to 2nd when cold. Put in Redline, no change. I just shift a bit slower until warm.
Postby Mr Morlock » Thu Jun 28, 2018 10:34 pm
The perfect manual change probably does not exist. Just change 1st to 2nd with a bit of care when its cold. A number of guys here are saying you can put magic brew # X in it and it works like vanishing cream and others dont think it makes any difference - technique helps and crash bang ultimately takes its toll.
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Thu Jun 28, 2018 11:54 pm
Search for this.
Genuine Ford Fluid XT-M5-QS Full Synthetic Manual Transmission Fluid - 1 Quart
Postby Okibi » Fri Jun 29, 2018 12:03 am
MT90
Postby Magpie » Fri Jun 29, 2018 8:48 am
One thing to consider that if the wrong oil has been used in the past it will take a fair amount of time for the old oil to be flushed from the system.
This also applies if you change to a different GL4 oil. Pick a oil and stick with it, it make take a few changes before you will notice a difference.
Postby 93_Clubman » Fri Jun 29, 2018 12:12 pm
Mr Morlock wrote:The perfect manual change probably does not exist.
NA6
Roadrunner
coyotes after you
Postby Roadrunner » Fri Jun 29, 2018 2:33 pm
I experience worse/crunchy cold shifting when I went from Redline Lightweight Shockproof to MT90 in the SE 6 speed.
Fine when warmed up.
Personally I'd use the Redline Lightweight Shockproof if you are having crunching now.
I never had crunching gear shifts when cold previously on the LW Shockproof and am considering dropping brand new MT90 out of the box :cry:
MeepMeep
RS2000
Postby RS2000 » Fri Jun 29, 2018 4:03 pm
See point 3 about MT90 on https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil that says:
"safe for brass synchros, as it lacks the reactive sulphurs found in most GL5 oils that cause damage"
Go to https://www.redlineoil.com/lightweight-shockproof & use the Compatibility Check:
If you select a 6 speed Miata LS or SE, it will say LW/SP is NOT recommended. Maybe it's GL5, as it is used for diffs?
This came up years ago in the NSCC. Some S15 owners (same 6 speed as MX5) reckoned LW Shock proof ate synchros. Others said they had no problem.
CrazyRacer
Postby CrazyRacer » Fri Jun 29, 2018 5:53 pm
Another vote here for Redline MT90. It transformed the 6 speed in my SE.
I don't know what had been in it previously (when I bought the car), but the gear change issues that it had disappeared with the MT90.
Roadrunner
coyotes after you
Postby Roadrunner » Sat Jun 30, 2018 1:01 pm
RS2000 wrote:See point 3 about MT90 on https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil that says:
That's very interesting. I've always been under the impression LW was GL4.
Also to note with that compatibility checker that for a 2003 NB it only has the option of a 5 speed manual or 4 speed auto, so may not be quite accurate.
MeepMeep
RS2000
Postby RS2000 » Sat Jun 30, 2018 11:59 pm
6 speed shows up for me when I select 2003 Miata or Miata SE or Miata LS.
Red_Bullet
Postby Red_Bullet » Sun Jul 01, 2018 1:01 am
I run MT90 in my 2002 6 speed, haven't noticed any real problem once warmed up. 1st to 2nd resists a bit when cold. I bought it coz it's GL4 and others reckon it works.
I only bought the Motorcraft stuff to have it on the shelf for when (and if) I stick the 6 speed in the NA8. I broke second gear in the NA 5 speed box (user error most likely) and had it replaced at Automotive Plus with another 5 speed as there was no 6 speed box available at the time. Here is what Plus put in it. Seems to work just fine, the 5 speed is a much nicer box to use than my much newer low km 6 speed in the NB. Hence my deliberations on putting the 6 speed in the NA. I'm kinda lazy too.
martini extreme pressure 75/80
edit more info:
Sint 75/80 Road & Track Gear Oil
An extreme pressure, low viscosity, lubricant designed for the modern high performance vehicle. Sint 75w80 R/T is suitable for the most sophisticated types of manual gearboxes or trans axles operating at maximum capacity. The advanced Synthetic* technology of this product will help to increase component life and greatly extend drain intervals. Sint 75/80 R/T meets all the requirements of the specification API GL-4.
Sint R/T Gear Oils meet or exceed the following specifications.
API GL4
MILITARY SPECIFICATIONS MIL-L-2105D, MIL-PRF-2105E
GENERAL MOTORS HN-1561, HN-2040
FORD MC20119 A, MC2-104
MACK GO-J * BORG WARNER 5M - 48
Sint R/T Gear Oils Should be used in manual transmissions that specify this type of high performance full synthetic gear oil.
CHARACTERISTICS 75W80
Viscosity Index : 152
Viscosity @ 100 C (cSt) : 8.8
Viscosity @ 40 C (cSt) : 55
wasp47
Postby wasp47 » Sun Jul 01, 2018 8:26 am
I have also found them to be very sensitive to slave cylinder condition and pedal adjustment. :NB8B:
Nevyn72
Postby Nevyn72 » Sun Jul 01, 2018 10:40 am
wasp47 wrote:I have also found them to be very sensitive to slave cylinder condition and pedal adjustment. :NB8B:
Don't forget engine mounts!
Worn or torn engine mount rubbers cause selection issues too. :wink:
