Muffler delete
- roshmx5
Re: Muffler delete
Thanks HKS what I think I will do is just have it straight through and leave it on there for a while. If I don't like it put a hotdog running east west where the muffler is. Thenexhaust place will make a flange so it is bolt on bolt off so if I need to refit OEM I can.
Mazda MX5 SP
- bruce
- Vehicle: NA8 - Turbo
Re: Muffler delete
Welded in an electric flap before rear muffler. Open the flap/valve and its opem to atmosphere. closed, it all goes thru muffler as standard.
Re: Muffler delete
roshmx5 wrote:Thanks HKS what I think I will do is just have it straight through and leave it on there for a while. If I don't like it put a hotdog running east west where the muffler is. Thenexhaust place will make a flange so it is bolt on bolt off so if I need to refit OEM I can.
That's a good plan.
Welding in a hotdog after the fact will be dirt cheap too, the welding should only be $50 or so, plus whatever the dog costs.
- roshmx5
Re: Muffler delete
Hi members
The muffler delete is done. It's not that loud, doesn't drone at all and the muffler shop took extreme care. Bolt on flange so I can put my other muffler on if I want to go back to original.
Mazda MX5 SP
- aka_juffa
Re: Muffler delete
Glad it worked out for you.
As Peter has already mentioned in a previous post, those MX-5s with turbos tend to be much quieter. I did a turbo upgrade to a NA6 a few years ago. I had to drive to an exhaust shop with no exhaust from the down pipe back. I was surprised how quite it was. In fact, with the exhaust pulse (I assume caused by the turbo) it sound very much like a WRX at idle.
J
J
