poor running mystery
Re: poor running mystery
Postby 93_Clubman » Tue Sep 06, 2016 4:14 pm
StanTheMan
Postby StanTheMan » Tue Sep 06, 2016 5:05 pm
all these years I was under the impression AU delivered NA6/8's didn't have that feature unless you go under the dash & install the light.....
Postby manga_blue » Tue Sep 06, 2016 5:34 pm
You really have stated all the typical symptoms of a blown head gasket. In your case there's probaby combustion gas blowing into the coolant and then coolant being sucked back into the combustion chamber on every stroke.
Virtually any small garage has CO detection kits these days, where they check for the presence of CO (combustion gas) in the coolant. Sometimes they'll find it in the top of the radiator but more often it shows up in the overflow tank. Either way it means blown head gasket.
The test itself takes about 1 minute and most workshops do it for free. I wouldn't bother chasing difficult electrical and sensor problems until I'd eliminated the most obvious solution.
speed
Postby speed » Wed Sep 07, 2016 8:56 am
^^^ this.
Was the head reconditioned, shaved or at least confirmed flat before the gasket was replaced?
Postby 93_Clubman » Wed Sep 07, 2016 11:35 am
StanTheMan wrote:all these years I was under the impression AU delivered NA6/8's didn't have that feature unless you go under the dash & install the light.....
Stan, from memory the LED & resistor is required for the ADM NA6, but the engine check light on the ADM NA8 is enabled.
Code4
Postby Code4 » Wed Sep 07, 2016 11:50 am
Was the head re torqued after the new gasket was installed ? Sometimes done after a few hundred kms in older engines.
Never put the top up unless the storm has a name.
