Mazda B6 DOHC 16V
StanTheMan
Re: Mazda B6 DOHC 16V
Postby StanTheMan » Fri Nov 25, 2016 9:54 am
The minimum distance between Piston & head clearance is .032-.059 mm once head gasket is installed
can anyone confirm that?
I'm getting figures up to .75mm from various places :shock:
madjak
Postby madjak » Fri Nov 25, 2016 1:54 pm
Are you sure that's not 0.032- 0.059 inches not mm?
It depends on a few factors. How heavy are the pistons, how many revs, rod strength.
Edit: What I wrote was misleading. Let me try again:
Piston to head: 35-40 thou, more if you have heavy pistons (up to 60thou)
Piston to valve: 80 thou intake, 100 thou exhaust. You can be a bit tighter but you need to know what you are doing.
Also FYI, my valves will hit each other too if you get the timing out. There is a cross over window where they miss each other.
StanTheMan
Postby StanTheMan » Fri Nov 25, 2016 1:56 pm
although Valve may be an issue I'm currently looking at how much clearance I have between the head & Piston. Probably closer to 0.3mm which is too close if
standard motor is be 0.75mm? pistons & con-rods are standard.
I got the figure from the 1990 Mx5 manual. It just talks about clearance.They may be talking about a different tolerance than I think they are talking about. Will check if hey talk about mm or inches
I'm talking about he minimum distance between the piston at TDC & the head bolted down on the head gasket. if 0.060" is the number that would be 1.5 mm before it hits the bottom of the head. The standard gasket is 1.2mm thick once compressed. In most cases the piston at TDC is above the deck..... I measured mine at 0.3mm and Ive read that it is normal .....
madjak
Postby madjak » Fri Nov 25, 2016 2:11 pm
StanTheMan wrote:I'm talking about he minimum distance between the piston at TDC & the head bolted down on the head gasket. if 0.060" is the number that would be 1.5 mm before it hits the bottom of the head. The standard gasket is 1.2mm thick once compressed. In most cases the piston at TDC is above the deck..... I measured mine at 0.3mm and Ive read that it is normal .....
I re-wrote what I typed... it was wrong as I was mixing in valve to piston.
I think 35 thou would be the minimum if you are aiming for revs. 0.89mm. At 0.35mm your at 13 thou?
StanTheMan
Postby StanTheMan » Fri Nov 25, 2016 2:14 pm
madjak wrote:Are you sure that's not 0.032- 0.059 inches not mm?
OK cheers were both editing :lol: :lol: :lol:
Its time to take the head off before it self destructs as well.
StanTheMan
Postby StanTheMan » Fri Nov 25, 2016 2:16 pm
Not aiming for revs. Just a bit more compression. and yes. very little tolerance if this is all true and most likey detrimental to the health of the piston & head
madjak
Postby madjak » Fri Nov 25, 2016 2:26 pm
StanTheMan wrote:Its time to take the head off before it self destructs as well.
Reading up on a few performance builds, I think 25thou would be my bare minimum. It sounds like the factory 1.6 has the pistons over the deck so it's around the 32-35thou mark as stock. You need to have room for the piston to rotate in the bore a bit as well as expansion of the rod.
When I pull down my engine at the end of the year I'll measure the clearance, but at 13thou I'm thinking it's all way to tight. You will see if it's been hitting.
StanTheMan
Postby StanTheMan » Fri Nov 25, 2016 4:07 pm
I'm hearing it at 4000 rpm.......
madjak
Postby madjak » Fri Nov 25, 2016 5:40 pm
yeah so it's not the piston hitting the valves, but rather the piston hitting the head. That makes more sense as I can't see how you'd hit with 272 degree cams even with a big head shave.
StanTheMan
Postby StanTheMan » Fri Nov 25, 2016 9:23 pm
Confirmed
Put the old cams back in. Noise is still there.
Lifters have plenty of oil in them. Quite smooth to move around as well.
Mind you. The 272 cams make a decent difference even with the standard ECU
Big torque difference mid range too. These are great for street
Oh well . Standard size head gasket will be on order. Hope there is not too much damage.
StanTheMan
Postby StanTheMan » Mon Jan 16, 2017 8:03 am
OK what about Knock sensors for stand alone ECU's.
I know most ECU's will have the possibility to add a knock sensor. Ive been reading mixed reviews.
https://www.flyinmiata.com/knock-sensor-and-mount.html
does anyone have any experience with this?
