cam cover advice
Ice88
Re: cam cover advice
Postby Ice88 » Thu Oct 29, 2015 11:28 am
Should get a capri valve cover or bpt. If i could I would :)
like dis:
Postby hks_kansei » Thu Oct 29, 2015 1:59 pm
smy0003 wrote:What do you have to do for the breather tubes with the astina cam cover?
Looks like it's missing the barbs.
Sorry not sorry for the thread hijack.
They have the PCV vents etc, just in different locations to the MX5
One points right at the firewall when fitted to an MX5 (not an issue on the 323), and while it's tight, you can still use it, just buy some hosing and route it differently to the OEM hose.
Alternatively, some people just block off that bent and drill into the side of the cover to fit a replacement barb in a similar position to the MX5 stock placement.
3gress
Postby 3gress » Thu Oct 29, 2015 8:11 pm
Cookie had a spare bpt block with that style of cam cover last time i was up there.
I wonder if he might part with it?
greenMachine
Postby greenMachine » Fri Oct 30, 2015 9:07 am
Chris, you selling that radiator? :lol:
:mrgreen:
Ice88
Postby Ice88 » Fri Oct 30, 2015 11:02 am
3gress wrote:Cookie had a spare bpt block with that style of cam cover last time i was up there.
Send him a message :)
Otherwise mat has one I think, could swap him a sway bar or something?
3gress
Postby 3gress » Sat Oct 31, 2015 10:56 pm
Now that i'm close to acquiring a bpt cover, i've mocked up the ford lynx one to consider if it is worthy.
What do you guys think? I like how the cover curves up to meet the front and the fact that it is just different to the more common standard mx5 cut cover or bpt option.
Also if anyone does have one of those old roadster floormat badges they'd consider selling, give me a yell.
Cheers.
Postby hks_kansei » Mon Nov 02, 2015 11:50 am
Personally I really like the laser one there, similar but different.
Badge options you could also look into sand casting, since it's pretty simple to build a small furnace.
Or see if someone with a 3d printer can do you a badge in high temp ABS plastic (I don't know what temps it starts to go weird though, you'd need to look that up)
ndragun
Postby ndragun » Tue Nov 03, 2015 11:21 am
I had my cam cover machined at a shop for 50 bucks to make way for my Maruha timing cover;
1994 MX5 Clubman
XIDAs, Wilwoods, 6ULs
project.r.racing
Postby project.r.racing » Tue Nov 03, 2015 6:46 pm
Looks good.
3gress
Postby 3gress » Sat Dec 19, 2015 5:03 pm
Here's a practice run at etching aluminium with ferric chloride using an artline permanent marker for an acid resist. Its freehand so a bit dodge 8)
The texta worked surprisingly well, the method was a bit 'ghetto' however results were promising enough to continue with a decent attempt.
Postby manga_blue » Sat Dec 19, 2015 5:27 pm
Actually it looks pretty good - really close to the original. Would a better image of my floormat badge help you?
madjak
Postby madjak » Sat Dec 19, 2015 5:39 pm
Google image search
3gress
Postby 3gress » Sat Dec 19, 2015 6:08 pm
Thanks for the offer manga, and madjak for the image.
Jaycar usually stock etching gear for etching pcb boards and the like for electronics. They also stock a diluted ferric chloride solution which is a fair bit safer than hydrochloric acid and easier to work over larger items as the etching process is slow and manageable.
The results above took around 10 minutes. I simply dripped the solution on with a paintbrush and gently agitated it while it bubbled away. When sufficent depth was achieved i doused the the aluminum in a bucket of water.
bear2230
Postby bear2230 » Thu Dec 24, 2015 10:40 pm
If you can wait until end of January I can make you up a plaque and laser etch it.
We just bought a Speed marker 1300 and I need to make some brass roadster plaques for a run of car mats.
https://www.youtube.com/watch?v=iJlYA20KhIY#t=66
I'm actually pretty exited about this new etcher. It's heaps of fun.
3gress
Postby 3gress » Fri Dec 25, 2015 5:37 pm
Sounds great. I might shoot you a pm soon about some bespoke designs too.
