the standard NA6 diff is as strong as a toothpick.
when you replace the internal diff with a Kaaz, it makes the diff a little stronger.
except the pinion gear is the next weak point IIRC.
so you will have a slightly stronger diff......but not by much.
Kaaz diff in stock na 1.6 housing
- StanTheMan
Re: Kaaz diff in stock na 1.6 housing
- StanTheMan
sailaholic wrote:There are alot of blown na6 duffs happening in QLD at the moment judging by Facebook. I'm not sure if age is finally getting to them of if the new owners are abusing them.
we've had this conversation countless times. It seems the racers break a lot less diffs than the dori, dori touge drivers.
But I recon age would have a lot to do with it & the way its dríven.
Mine went a good 10 years ago......didn't take much to break it when it did break. It was perhaps more like the twig which broke the possums back.
