Naturally Aspirated Mod's - Motors Coming out
booki89
Re: Naturally Aspirated Mod's - Motors Coming out
Postby booki89 » Mon Aug 18, 2014 9:01 pm
I thought I had to change the whole diff housing/shafts and everything.
But if its just the centre, I should be able to get a centre and swap it out :)
There are some real cheap kits out there for timing belt and water pumps, but have chosen these two. Thoughts?;
http://www.amazon.com/FMI-20705-Premium ... da%3Amiata
http://www.amazon.com/Gates-T179RB-Blue ... da%3Amiata
Postby manga_blue » Mon Aug 18, 2014 10:20 pm
The water pump is unbranded - I wouldn't buy that one. There are some nasties about. Look for a GMB one instead, they're the OEM supplier and the price should be about the same as that one.
The Gates belt is good but you do need to replace the two idlers at the same time. Look for a kit.
You must go genuine for the crank seal, the crank bolt and the key. That means ony MX5parts.co.uk or Mazda Australia.
Users browsing this forum: No registered users and 21 guests
