mechanical squeak??
Gladiator
Re: mechanical squeak??
Postby Gladiator » Tue Aug 05, 2014 9:57 pm
Have you tried Pezchops fix? He was spot on for my squeak.
revhead
Postby revhead » Tue Aug 05, 2014 11:56 pm
No I have not tried it yet, but it seams easy enough to do so shouldn't take long to try it out. The squeak is intermittent so will be hard to tell if it fixes it in the long run. I actually still need to do my gearbox oil (I can't break loose the fill and drain plugs or fear of rounding them, especially the square shaped fill plug) so I will dab some grease on the clutch pivot joint when I am under the car with my next attempt.
4sfed5
Postby 4sfed5 » Sat Aug 09, 2014 10:00 am
Very common for the bonnet hinges to squeek when its closed.
Vat
Postby Vat » Tue Aug 19, 2014 5:44 pm
taminga16 wrote:Purchase a can of 'Lanoline', put the car onto some stands and lube every bush and check the engine mounts, use a lever and don't forget the rear one.
Greg.
Bit of a necro but I did this yesterday, as well as a bit of white lithium grease on the door hinges and, most effectively, the hinges in the seats. Took quite a bit of noise out and, to be honest, the Jaffa felt a bit fresher to drive (may have been the noise reduction).
Thanks for the tip, much appreciated.
'98 Evo Gold NB8A
QR-Clubman 66.5109|Sprint 63.3635|Sportsman 67.4673|National 92.3481|Lakeside 65.7478|MP K 1:35.382|MP E 1:16.422|NM 1:08.017
