Short shifter rattle
davekmoore
Re: Short shifter rattle
Postby davekmoore » Sat May 10, 2014 11:31 pm
The green bush supplied with the short shifter kit is now working perfectly with a couple of tight fitting washers in the turret beneath the washer. All rattles, buzzes etc are now gone, even though I lost the wobbly washer in the reassembly process.
Corey
Postby Corey » Thu Apr 28, 2016 9:09 pm
Sorry to revive a dead thread, could you elaborate more on how you fixed this? I have the same issue. Cheers.
davekmoore
Postby davekmoore » Fri Apr 29, 2016 10:04 pm
The May 2014 fix only worked for a while.
IL Motorsports Mk2 version of their shifter with nylon inserts has been a longer lasting solution. It, too, has been buzzing slightly recently but this might be to do with the recent discovery of only 3.5 of the 6 engine mount bolts being present and/or the correct size and/or tightened.
