Best bang for buck mod ever??
davekmoore
Re: Best bang for buck mod ever??
Postby davekmoore » Wed Apr 09, 2014 11:51 pm
Okibi wrote:
davekmoore wrote:...I'll appreciate others' opinions please on how to make a bush to cover the top of the leather gaiter that used to fit the bottom of the gearknob perfectly but now flaps about on the thinner lever extension...
A bit of rubber hose over the extension should fatten it out enough for the gater to stay up, stick a washer on top of the hose it if needs to be wider.
Done that. Works great. Top of hose exact fit to bottom of gear knob. Internal diameter of hose just a bit too large so taped the extension so make it bigger.
The extension also seems to have stopped nearly all of the transmission of heat up the gear lever to the gear knob. Now need to find a way to stop all that unwanted heat coming out of the transmission tunnel and the heater.
Snowmotion
Postby Snowmotion » Thu Apr 10, 2014 12:38 pm
davekmoore wrote:
Okibi wrote:
Have a look at this
http://www.ebay.com.au/itm/Miatamecca-Insulation-Heat-Shield-Floor-Tunnel-Cure-For-Miata-MX-5-Hot-Foot-/390436403927?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ae7d2bad7
I fitted this to my NB and has definatley reduced the heat from the tunnel. Not too bad to fit but watch the video first for fitting tips. Also don't let it sit too far forward or the tunnel opens up too much to get it to stick. I did this but despite that it is still sitting perfectly in place after 1 track day.
Postby Okibi » Thu Apr 10, 2014 3:54 pm
Snowmotion
Postby Snowmotion » Thu Apr 10, 2014 4:32 pm
Yes similar.
The Miatamecca ebay guys refunded me $5US as it was an international order. So cost all up was $60.
And there stuff really sticks.
Users browsing this forum: No registered users and 85 guests
