The stronger it is the harder it turns the engine over the harder it pumps the compression gauge up.
Sorry If that came across aggressive.
Are these compression test results ok?
- NitroDann
Re: Are these compression test results ok?
- Vehicle: NA6 - Turbo
Ahhh ok, now I understand. No it didnt come across as agressive at all.
Appreciate your help.......again
- NitroDann
There is a limit, and that limit is how powerful the starter motor can be.
Long story short the test needs to be done at operating temp, with a jumpstart to ensure the starter is going full power and with the throttle wide open to get all the air in you can.
If it wasnt done like that it doesnt count.
If the car want being run on a jump start the first time around, the performing the rest differently the second time around is likely to give different results.
93_Clubman wrote:sticky nicky wrote:I had a compression test today and they came in at 140, 143, 140 and 143.
Bit of a contrast from a year ago - hope it's just the tired battery!sticky nicky wrote:Just had my replacement engine (1.6, long nose crankshaft) tested for compression before it goes in. Results were 225, 225, 225, 175.
viewtopic.php?t=54462&f=29
OK, so a got a new battery from RAC $235.00
So I guess thats better, the mechanic did put a Cometic head gasket on as well but not sure of the thickness, so maybe thats a reason why its a bit lower as well.
The higher results (225, 225, 225, 175) were done when the engine was sitting in a trailer, so I gather you can get acurate results when its not cranking in your car?
- NitroDann
Yes, either way its important that the engine have its throttle FULLY open.
Users browsing this forum: Bing [Bot] and 2 guests
