Weird Sump Seal Issue (Engine assembly)
gslender
Re: Weird Sump Seal Issue (Engine assembly)
Postby gslender » Sun Jun 02, 2013 8:52 pm
One thing to consider is to wait 1 day before torquing down. Let the goo and seal press together, firmly, but not torqued down. Then let it fully dry overnight, and then torque down. I did this on all items that had sealant applied, and I've not had a single issue with oil leaks, or bulges etc.
I was told this by an engine builder once, and it sounded reasonable. Otherwise you can end up squeezing all the sealant out and leaving such a small amount it can break away and offer a gap over time. Leaving it to dry tight but not torqued allows a thicker amount of sealant that will stay together but thin enough to be torqued up.
That might help?
G
olboy
Postby olboy » Sun Jun 02, 2013 8:58 pm
It appears that the seal is soaking up the silicone
Is the seal longer when you take it out ?
Does it shrink back after a day or so ?
If so I would change the brand of seal and the brand of silicone
Olboy
