93_Clubman wrote:ok - check ECU PCB for any discoloration or other obvious signs of an issue, also check earthing points.
ive checked and cleaned all earthing points and i cant get my ecu open because the screws are stripped
mewse wrote:ive checked and cleaned all earthing points and i cant get my ecu open because the screws are stripped
mewse wrote:93_Clubman wrote:ok - check ECU PCB for any discoloration or other obvious signs of an issue, also check earthing points.
93_Clubman wrote:The ECU Phillips head screws can strip fairly easily if moisture has been present in the vicinity (common).
