gearbox troubles
- Vehicle: NB8B - Turbo
Re: gearbox troubles
Pulled the gear shaft out and this is what i found, might be the reason to my troubles.
- gslender
I'm not sure these would resolve what sound more like synchro problems, but fixing the boots and nylon locator certainly makes the gear changes more firm and removes any floppy play. I'd be changing the gear oil for at least a Redline and you should find the changes improve.
I changed to that that Motorcraft special gear oil, and it has dramatically improved my changes in what was already a fairly smooth gearbox. Oil quality can make a big difference.
G
G
- Learner Driver
Can you PLEASE share where you managed to find the motorcraft gearbox fluid? I searched the entire Internet to find somewhere that would ship to aus or is located in aus...
Ollie
Ollie
- -alex
My na8 5speed dropped 1st, 3rd and 5th randomly last year. After having lots of difficulty getting it into 5th then problems with it popping out when not under load.
Pretty sure random short shift kit had something to do with it.
1.5k later and I've got a "new" used 5speed nb box, new clutch and spigot bearing fitted and a mazdaspeed short shift kit, despite a bit of work and some fussing around sourcing the GB it's been simple.
By all means try the above suggestions but its also nice piece of mind to just start over.
- gslender
opilot87 wrote:Can you PLEASE share where you managed to find the motorcraft gearbox fluid? I searched the entire Internet to find somewhere that would ship to aus or is located in aus...
Ollie
I got it when this GB was run... so I can't help you, but you might wish to talk to the person who organised it.
viewtopic.php?f=44&t=53260&hilit=motorcraft
Tensa Zangetsu wrote:my gearbox won't go into 5th and has trouble getting into reverse, if i grind it into 3rd it'll grind into 5th, and i have to be rolling to get into reverse, anyone got any ideas?
http://www.google.com.au/#hl=en&sclient ... 24&bih=571
