Diff Strength
toppertee
Re: Diff Strength
Postby toppertee » Sun Sep 02, 2012 7:26 pm
BOYRCR wrote:
flycasta wrote:270HP isn't the issue...... The issue is what you are doing with it.
I know the Main issue is my driving style. I am rough on the car. That's why I'm upgrading every thing as I go so I can do full rpm launches at the drags and flat change gears around a track.
I think I am going to install the Cusco LSD and see how it goes. If I have issues with the stub axles or centre again I will have to have a look at the Getrag diff and stub axles. I think they will be the strongest option and for around $2,000 + diff it doesn't seem that bad.
s#it yeah!!!
Vett diff in the rear!!! Nice one :beer:
BOYRCR
Re: Diff Strength
Postby BOYRCR » Sun Sep 02, 2012 8:07 pm
NitroDann wrote:I would just do a TII driveline swap.
FC 5 speed with adaptor plate or welded bellhousing, and one extra mount welded to the rear subframe, custom driveshaft and a rear gearbox mount, no PPF.
That's all well and good when you have a clean slate and can plan your build from the start and not when you have spent $7,000 plus on the gearbox and clutch. I need a solution that will work with the gearbox I have now. Like a diff centre (fingers crossed) or a Getrag and stub axles.
I hope the diff centre isn't a band aid and it let's go in the spectacular style of the last one. If anything breaks I hope it is the stub axles. That way I can sell the whole diff as one and put it toward the Getrag.
If it aint on the rev limiter then you shouldn't be behind the wheel!
Re: Diff Strength
Postby NitroDann » Sun Sep 02, 2012 10:37 pm
FC diff alone then?
Very very easy to adapt.
mx52nv
Purple Porsche Eater
Re: Diff Strength
Postby mx52nv » Tue Sep 04, 2012 6:50 am
Brett,
How about a Getrag or Ford diff conversion as used by V8Roadsters with a custom driveshaft from Veem? Talk to Keith or Jeremy from FM and your local Veem for prices.
Les
