Na8 misfiring & engine shutting off
Re: Na8 misfiring & engine shutting off
Postby manga_blue » Fri Aug 31, 2012 1:57 pm
nelson92 wrote:
hks_kansei wrote:Just out of curiousity..... how did you clean the AFM?
IIRC they're pretty sensitive, so it doesn't take much to ruin one.
sprayed brake cleaner in it and let it dry.
The only safe way to clean an NA8 or NB MAF is to spray it with either isoropyl alcohol or a special circuit board/contact points cleaner. No other solvents and no touching the internal wire.
For washing the engine itself you shouldn't use any products containing caustic soda. It attacks aluminium and electrical contacts.
nelson92
Postby nelson92 » Fri Aug 31, 2012 2:12 pm
Ill keep that in mind for next time, funny thing is after i had cleaned the afm and throttle body, it ran like a dream its only after i had washed the car this happened, and i only cleaned the exterior only.
Postby 93_Clubman » Fri Aug 31, 2012 2:24 pm
nelson92 wrote:funny thing is after i had cleaned the afm and throttle body, it ran like a dream its only after i had washed the car this happened, and i only cleaned the exterior only.
So it's had the misfire since you bought it in early May '12, except after you cleaned the AFM & TB:
nelson92 wrote:and I've always had this misfire until recently I cleaned out the throttle body, afm and it started to run perfect but today it started to misfire again and even shut down
Postby bruce » Fri Aug 31, 2012 5:38 pm
Did you remove the AFM when squirting in the brake cleaner, or did you leave it on the engine?
Postby manga_blue » Fri Aug 31, 2012 6:18 pm
I hate these intermittent faults. If it were my car I'd open each of the main engine connector plugs and earth straps, check them out closely for water/oxide and give them a clean with IPA. That means CAS, MAF, TPS, O2, coilpacks, engine harness and the earth straps at front right, rear left of engine and to PPF back near the diff. If it still misses at least you've got a base for finding out which sensor is causing it. Your friend's probably right though. If it's a sensor then MAF is the most likely one. Can you borrow one for a test?
nelson92
Postby nelson92 » Sat Sep 01, 2012 10:27 pm
yep early may this year and yep after that too.
bruce wrote:Did you remove the AFM when squirting in the brake cleaner, or did you leave it on the engine?
i removed the afm.
manga_blue wrote:I hate these intermittent faults. If it were my car I'd open each of the main engine connector plugs and earth straps, check them out closely for water/oxide and give them a clean with IPA. That means CAS, MAF, TPS, O2, coilpacks, engine harness and the earth straps at front right, rear left of engine and to PPF back near the diff. If it still misses at least you've got a base for finding out which sensor is causing it. Your friend's probably right though. If it's a sensor then MAF is the most likely one. Can you borrow one for a test?
so far whats happened is, on friday it rained, i assumed my car would run like sh*t on the way home from work, but it was fine until i was almost home it decided to misfire once or twice and today driving to work and back, it misfires a couple of times and that was it.
i have absolutely no idea, but im gonna be checking under the dash cause when it switched off on me, i heard a sound from under the dash, something like a loose connection.
Postby 93_Clubman » Sun Sep 02, 2012 1:30 am
nelson92 wrote:im gonna be checking under the dash cause when it switched off on me, i heard a sound from under the dash, something like a loose connection.
Could also be an aftermarket immobiliser with an intermittent fault, or one that has been partially disconnected & is shorting. Also worth noting that the OEM ECU is under the dash on the passenger side footwell firewall.
nelson92
Postby nelson92 » Wed Sep 05, 2012 9:03 pm
You may be right with the shorting.
today i decided to get under the dash and see if there were any loose wires or anything and while i was moving the harness around, i tried to start the car, it cranked but didnt fire, mate came around and whacked on the test light and no light. he tried going under and moved some looms around and it fired.
im thinking about getting a auto electrician to come around and clean up the mess under there.
any suggestions?
Postby 93_Clubman » Fri Sep 07, 2012 12:26 pm
nelson92 wrote:im thinking about getting a auto electrician to come around and clean up the mess under there.
any suggestions?
Have you identified an immobiliser amongst the mess under the dash? If so, & you don't feel confident enough to sort it yourself, either due to limited auto elec knowledge, unknown brand of immobiliser & therefore a lack of immobiliser manual, or lack known immobiliser manual availability, then definitely get someone to assist with sorting the issue. Of course it could be that someone has already hurriedly removed an immobiliser & left the wiring in a mess. Again, if you've not got the knowledge to do it def get assistance. Wiring diagrams for NA8:
http://neomiata.com/garage/index.php?pa ... 1990-1996/
Btw, when looking for the appropriate manual, the NA8 was first released in US as MY1994.
nelson92
Postby nelson92 » Fri Sep 07, 2012 12:44 pm
any suggestions?
Thanks for that 93_clubman.
There is a immobiliser, the brand is autowatch. I find that it works fine but I'm sure there is a short somewhere, just not sure where to look.
I'd appreciate it if a forum member can help or assist me or If he/she has done it before, I'm willing to throw some beans over.
Postby 93_Clubman » Fri Sep 07, 2012 2:11 pm
nelson92 wrote:There is a immobiliser, the brand is autowatch. I find that it works fine but I'm sure there is a short somewhere, just not sure where to look.
nelson92 wrote:I'm located in Sydney Liverpool area.
Good luck Tom - perhaps a local can assist. Someone posted a few months ago that were going to try removing their immobiliser, but have since gone quiet I think. It can be a difficult job for obvious reasons. Btw, Dynamco & Autowatch Australia merged last year: http://www.dynamco.com.au/
nelson92
Postby nelson92 » Fri Sep 07, 2012 6:44 pm
Thanks for the suggestions and quick replies 93_clubman, i appreciate it, will keep this thread posted.
cheers
tom
nelson92
Postby nelson92 » Tue Sep 25, 2012 9:17 pm
ok car seems to be driving sweet, can finally say im enjoying it after owning it for a few months now.
the problem was a loose wire from the immobiliser that controlled the fuel and spark.
cheers for everyones input.
tom
Postby 93_Clubman » Wed Sep 26, 2012 12:27 pm
Good to hear a problem was identified & that it's now running well.
Users browsing this forum: Google [Bot] and 3 guests
