What pumps are available that could do the job? How thick is super hot gear oil?
Silly ideas, would there be enough of a cooling affect provided in adding extra material to the gearbox....Like the sump on the A series engine found in the mini...
NitroDann wrote:Mini rally cars understeer like a bitch in mud because of those fins.
Pretty funny actually.
Sailor wrote:http://www.nengun.com/zele-performance/rear-differential-oil-cooler-kit
Adapt something like this....
Okibi wrote:Could you just keep it simple and not use a pump, keep an oil cooler below the standard oil level in the box and just let convection through the oil transfer the heat to the cooler.
Apu wrote:I just woke up from my fainting spell after seeing the price of that Nengun kit...$2000+!!
bruce wrote:This might sound silly. But howabout trying to eliminate the cause of the problem, the proximity of the exhaust? Anyway of getting something difft constructed further away from the gearbox?
greenMachine wrote:You don't need a filter block to monitor temps, you can get in-line housings.
