Thermostat modifications
Re: Thermostat modifications
Postby manga_blue » Wed Jan 04, 2012 12:13 am
1red5 wrote:With all your track-work though, you wouldn't consider a Mishimoto one?
At the moment I'm using a 72deg thing that was meant for something like a Bedford truck. It was the biggest low temp thermostat I could find. Cost about $8 and I ground down the mounting disk until it fitted in the MX5 housing. It's good for track but low temp thermostats (including Mishimotos) do have some downsides. Using the OEM ECU I can tune the mixtures for fuel in open loop but can't do anything about fuel in closed loop, so it runs a bit rich as a daily driver. To get better daily economy I can either run a resistor across the ECT sensor or go back to a standard thermostat. It's easier to do the latter.
Previous aftermarket ones have given me issues with slow opening rates. On a really hot day at the track the temp can rise 30-40deg in the course of a single lap, even on my fairly stock motor. Some of the cheaper thermostats can take over 2 minutes to open when dropped in boiling water. So on lap 1 the coolant can boil inside the head before the thermostat opens.
Postby 93_Clubman » Wed Jan 04, 2012 12:19 pm
Reminds me of CT's comment on thermostats:
viewtopic.php?f=29&t=17210&p=203814#p203814
Basho
Postby Basho » Wed Jan 04, 2012 1:15 pm
93_Clubman wrote:Reminds me of CT's comment on thermostats:
Damn I wish I hadn't read this thread , I picked up on this , http://miata.net/garage/CoolingSystemProblems.html , why the frack am I using 33% coolant which actualy does nothing to help with cooling but at that concentration will protect me against -20c of frost , I live in SE Queensland FFS what am I doing prepping the car for it's next owner who will have to live in Siberia ?
So far I'm actualy running on demineralised water to flush out the system and whilst I get new radiator hoses organised so when I fit the new hoses I schlep in coolant with the knowledge that it does nothing to help the cooling and roots thermostats.
Brilliant--whats wrong with this picture ?
greenMachine
Postby greenMachine » Thu Jan 05, 2012 5:36 pm
Corrosion.
:mrgreen:
eskimo
Postby eskimo » Thu Jan 05, 2012 10:37 pm
RX-747
Postby RX-747 » Mon Mar 19, 2012 6:00 pm
I know this is a bit off topic but does anyone know the dayco part number for the thermostat and thermostat gasket for NB8A mx5?
