NC bad habits
inbetweendaze
Re: NC bad habits
Postby inbetweendaze » Thu Sep 15, 2011 10:29 pm
G'box change into second very difficult when cold, no change from 17k to 35k (current). Tried Castrol 75W - 85 VMX, then Mobil Delvac Synthetic Gear oil 75W-90, no particular difference w.r.t. change into second. Mobil is expensive. Had to purchase 20l from distributor - so will keep me going for a while. Seems to work well in the LSD. If you find a solution by simply changing oil it would be welcome news.
"Anything that happens before or after... is just waiting."
deanb90
Re: NC bad habits
Postby deanb90 » Fri Sep 16, 2011 12:41 am
Nulon G70 additive helped a little. Extremely easy to put in so i would recommend since it's only $15
taminga16
Re: NC bad habits
Postby taminga16 » Wed Sep 21, 2011 3:43 pm
I purchased my NC in 2009 without a test drive, left my NB at the dealer and got a lift to the airport, one thing lead to another and it was almost three weeks before I picked up the new car and I will never forget the shock and horror that I experienced when I first drove it, admittedly my NB was running redline and had I had just fitted new boots (top and bottom)
but this new thing was akin to driving Tomas the Tank Engine on a bad day, a few shifts at normal running is enough to settle everything down and it only gets better from there on. An up-spec oil may fix the cold shift issuses but I doubt it, and on the point of bundling the NC gearbox in with past 6-speeds, If my memory serves me correctly the G/box has been totally re-engineered with triple syncros on the first four gears, a one piece shift linkage and repositioning of the gear lever for a more direct feel.
Enjoy.
Greg.
4sfed5
Re: NC bad habits
Postby 4sfed5 » Fri Oct 14, 2011 8:00 pm
i remember reading on Mnet a guy cured the gearchange issue but it involved pulling the gearbox and re-doing the thrust washers???
initial D
Re: NC bad habits
Postby initial D » Fri Oct 14, 2011 8:02 pm
I only put Red line in my NB, made the worlds biggest differance.
NC2005
Re: NC bad habits
Postby NC2005 » Sun Oct 23, 2011 5:28 pm
Have 2 NC's. One a 2005 (55000km)and other a 2009 series 2 (15000km)......Both 6 speeds.
Havent noticed second gear issues when cold on either, ever..
deanb90
Re: NC bad habits
Postby deanb90 » Sun Nov 20, 2011 7:59 pm
rev hunting solved -
I picked up some throttle body cleaner this morning, took off the intake and realized I have no air filter!? don't know what happened there. cleaned the throttle body and now no rev hunting, it was filthy. will be getting an air filter before my next drive
cheers
dean
Steampunk
Re: NC bad habits
Postby Steampunk » Sun Nov 20, 2011 8:22 pm
either a careless mechanic, or young guy removed it to get the extra 0.08kW of power.
I'm assuming the NC has a hotwire MAF? If so, I would also look into gently using some CRC MAF Cleaner
Re: NC bad habits
Postby NitroDann » Sun Nov 20, 2011 8:27 pm
Isnt the throttle body an air filter?
It filters out all particles larger than 65mm lol.
Old Dude
Re: NC bad habits
Postby Old Dude » Sun Nov 20, 2011 8:36 pm
NitroDann wrote:Isnt the throttle body an air filter?
Dann your a Wally.........What about the 50mm particles.....what's going to filter them :lol:
cheers
Dale 8)
MX 5 2001 Grace Green
NB8B
Re: NC bad habits
Postby NitroDann » Sun Nov 20, 2011 8:38 pm
The valves mate :)
deanb90
Re: NC bad habits
Postby deanb90 » Sun Nov 20, 2011 10:51 pm
lol @ dan, yeah i found a brick in the airbox, the throttle body is doing its job well!!
I bought it off an old bloke. I have not had it serviced yet as it has had a service 4000kms ago. Roadworthy was included in sale to so i am not sure what has happened.
Re: NC bad habits
Postby NitroDann » Sun Nov 20, 2011 11:48 pm
deanb90 wrote:lol @ dan, yeah i found a brick in the airbox, the throttle body is doing its job well!!
Made my night, cheers mate.
Must be making HUUUUUUUGE power to suck a brick into the airbox !!
