Has my engine pooped itself?
Re: Has my engine pooped itself?
Postby 93_Clubman » Wed Aug 31, 2011 1:54 pm
adrianciaff wrote:...the lifters were ticking as if it were low on oil.
Clearly from your description the oil level was very low, but HLA ticking noise in the NA6 & NA8 is more commonly due to other factors. In other words, the oil level can be fine & HLAs can still be noisy.
Hope the fix is a cheap & simple one.
Dweezle
Postby Dweezle » Wed Aug 31, 2011 2:07 pm
I changed the oil immediatley after using the suburu cleaner.
Then every start up afterwarda for the next 8 months would look like a fire extinguisher went off in the garage.
Maybe a co-incidence?
Was told it was most likely the valve stem seals or a stuck oil control ring.
Was warmed up it was fine.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
adrianciaff
Postby adrianciaff » Thu Sep 01, 2011 8:23 pm
So as most of you may have guessed... from what i can gather anyway - the piston rings are gone and possibly also the valve guides/seals which may have been caused by the subi cleaner ripping off all the solidified deposits which mated to the rings and seals as a result of 11 years neglegence. It may also be due to the simple fact that i gave it a hard go over the last 2-3 months which it most likely was not used to. (i doubt it ever new what >3000 RPM was)
I have put 20-50w oil in for the moment. It has slowed the oil buring process, however the car still blows smoke finatically on cold startup...a new motor is well and truly on the horizon.
Lessons to be learnt: Dont use subi cleaner on a motor you know has been neglected
I still havent done a compression test yet, im keen to find out if all cylinders are working properly or not.
Thanks all alot for your input it has really helped,
Adrian
adrianciaff
Postby adrianciaff » Sat Sep 03, 2011 5:13 pm
took out all the spark plugs today, cylinder 1 spark plug was covered in oil even after not being dríven for 2 days..
It is well and truly f***ed lol.
Postby Mr Morlock » Sat Sep 03, 2011 5:43 pm
I suggest just get the comp check done and diagnosed by a good mechanic- the check will tell you the state of play.
Kobsy
Postby Kobsy » Sat Sep 03, 2011 10:42 pm
Keen to hear the results of a comp check!
Btw...this sounds like a good oppitunity to do some engine perfomance mods. 8)
1999 Red NB8A MX-5
red devil
Postby red devil » Sun Sep 04, 2011 11:25 pm
sorry to hear that bud
Good luck with it all!!
Eren
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
Users browsing this forum: Bing [Bot] and 6 guests
