Town and Country exhaust opinions!
pcmx5
Re: Town and Country exhaust opinions!
Postby pcmx5 » Tue Aug 16, 2011 6:00 pm
pcmx5 wrote:josh, next week sometime.I am sure that this will not change the sound as the outlet is still the same, just that the tip looks physically bigger.
Will post the results,
Peter.
Exactly Dan and that's why i am doing this,I'm not changing the inside diameter.The tip is 3inch on the outside but 2 1/4 inside and "filled in" in between for want of a better term.(Apparently called dual layer in the trade)
Peter.
91 Malibu
Postby 91 Malibu » Tue Aug 16, 2011 6:44 pm
toymx5 wrote:Sorry to confuse you all but on my full T & C system I have a oval shaped chrome rolled tip that's 3 1/4'' x 2 3/4'' and it doesn't drone at all and sounds amazing and has all the performance gains of the normal T & C system using the standard sized tip. PCMX5 has heard and dríven my car and can attest to this. He was there when the system was fitted.
Have been lucky enough to have dríven this well sorted car, It has a great purr to it.
As Pete said hope to catch up with you soon, if you are going on the GOR run maybe we can head to the starting point together.
Cortina MK11 GTL
Mazda 3 SP23 Daily drive
Postby NitroDann » Tue Aug 16, 2011 9:32 pm
Peter.
Peter.
Yep thats definately the way to go.
frostex
Postby frostex » Tue Aug 23, 2011 4:10 pm
Is there anybody closer to greensborourgh area with one of these exhausts installed so i could have a listen. Definitly considering getting it done with all these glowing reviews.
pcmx5
Postby pcmx5 » Tue Aug 23, 2011 5:49 pm
frostex, you have a pm.
Peter.
Postby manga_blue » Tue Aug 23, 2011 6:22 pm
Just to throw in my 2c worth here. I've had a T&C built system on my car for 3 years now. It's done about 30 track days, been dragged through the kitty litter, bellied out in the mud and bounced off ripple strips forwards or backwards more times than I'd admit to, as well as done 30,000km on the roads, including a fair bit of dirt. There's never been a peep of trouble with it during all that time.
When we cut the front off it to do some mods to the header pipes last year we had a close look at T&C's workmanship. Perfect welds; the 2.25" front pipe had been smoothly flanged out into the 3" cat convertor and the interior welds had been shaped out with a die grinder. Not a crack or a bend in any of the system and no signs of it hitting or rubbing anywhere.
My previous system lasted less than 6 months, belted into oblivion by general manga abuse. T&C were a higher cost up front for me but much cheaper in the long run.
pcmx5
Postby pcmx5 » Wed Sep 07, 2011 6:04 pm
nanotech wrote:So have you actually booked in to change your tip Peter? I'd love to hear back from you about the sound of it! Otherwise I'll head in to see Collin and talk to him personally. Would be great to hear a testimonial first.
Also pricing!
Josh, finally got around to having a 3 inch outside diamenter 2 1/4 inside tip fitted and it has made no difference to the great sound but looks heaps better.$70 as a one off purchase or $35 on top of the one usually fitted to their system.
Go for it!,
Peter
Tony
Postby Tony » Wed Sep 07, 2011 6:35 pm
Gidday Peter, it's Tony here.
Do you have a photo and part number you could share? I'm keen on doing something myself, but would like to source locally if I can.
Ta...
'09 NC2
pcmx5
Postby pcmx5 » Wed Sep 07, 2011 7:17 pm
Tony, you have a pm.
Peter.
Mr nanotech
Postby Mr nanotech » Wed Sep 07, 2011 9:14 pm
Hey Peter can you please send me a photo as well?
pcmx5
Postby pcmx5 » Wed Sep 07, 2011 10:57 pm
nanotech wrote:Hey Peter can you please send me a photo as well?
I have no photo's josh just call by T& C tp see one.
Peter.
Mr nanotech
Postby Mr nanotech » Wed Sep 07, 2011 11:28 pm
how long did the whole thing take you? Oh and can you see the small tip inside or is completely hidden
pcmx5
Postby pcmx5 » Wed Sep 07, 2011 11:52 pm
Took all of ten mins to fit, they cut off the other tip and welded the new one on.From the back you see a 3inch outside diameter tip and a fill in to the 2 1/4 inside pipe.nothing else.
Give me a call if you want to see it on my car,
Peter.
Mr nanotech
Postby Mr nanotech » Thu Sep 08, 2011 12:30 am
Yeah i'd like that, I might give you a buzz some time tomorrow or Friday. That or just cruise by TnC. If they have a spare 10mins I'll see if I can get them to do it on the spot lol
kelvinator
Postby kelvinator » Thu Sep 08, 2011 12:17 pm
Wow! So many glowing reviews, I reckon I'm sold.
I have some time off later in the month and may make the drive over. Any guides on cost and what the system consists of? Full system, including headers and cat or cat back?***
A nice 8+ hour drive home should burn it in nicely or what better excuse for a GOR trip on the way back. 8)
***Derrrr.....Probably better to give them a call myself. Just did that and seems very reasonable. Will get the cat as well. Mine is probably overdue being on there for nearly 20 years. Roll on end of September!!!
