"Notchy" gear changes when cold
Noddycar
Re: "Notchy" gear changes when cold
Postby Noddycar » Mon Aug 01, 2011 4:01 pm
Ha ha.... Turned out it wasn't leaking. I assumed it must be coming from the drain plug, but when I wiped it clean, no leak! There was a little residue underneath from when I first drained it, so I can only assume once it heated up it started to drip.... I checked the level and all was perfect and the plugs are still dry after some spirited driving.
Like your idea, but thought I better not try that without a rollbar... :D
1993 MX-5 Limited Edition - my original Noddy Car
2010 Roadster Coupe Sport - the more civilised (but still fun) daily driver
