Re: Engine Rattle on Cold Startup
Postby NitroDann » Thu Jun 16, 2011 12:14 pm
Sorry. Fair point. getting a little focused here haha :mrgreen:
Black miata
Postby Black miata » Mon Jun 20, 2011 10:46 am
Thanks for the help guys.
Got it looked at by MX5 Plus and they said it is the shutter valve that has broken so will get that replaced and see how it goes :)
It started to get worse the longer i drove so thought i would take it in to get looked at :)
Postby NitroDann » Mon Jun 20, 2011 11:39 am
By shutter valve you mean the idle oil pressure valve in the head?
Postby 93_Clubman » Mon Jun 20, 2011 11:52 am
Think they mean the shutter valve actuated by the just left of centre round black topped VICS shutter valve actuator with the vacuum line to it pictured here:
http://www.fototime.com/%7B8CADB2F1-31C ... icture.JPG
Postby NitroDann » Mon Jun 20, 2011 12:39 pm
Im not familiar with VVt heads.
So This is part of vvt or what? This is the valve that controlls VVT valve oil pressure?
Postby 93_Clubman » Mon Jun 20, 2011 1:23 pm
No VVT on NB8A, just VICS - VVT was introduced on NB8B along with VTCS.
My understanding on the NB8A is the shutter valve actuator controls the VICS butterflies in the intake manifold via the shutter valve.
Postby NitroDann » Mon Jun 20, 2011 1:26 pm
Sorry I skimmed through and didnt read v i c s.
Black miata
Postby Black miata » Mon Jun 27, 2011 11:48 am
Hey guys,
I have gotten the new shutter valve installed which has fixed one issue but i have not come across another :(.
When cruising at 60km/h well any speed and I lightly put the accelerator down there is a fast paced rattle coming from the engine.
The motor has only got 2,000km's on it since the rebuild.
The MX5 is currently at the mechanics with the top of the engine dismantled but they can not track down what is causing the noise. They have looked for the defect that i am aware was common on the NB8A's but its not that.
It was quiet but after the install of the shutter valve it has gotten worse.
Has anyone has this issue before at all or herd of it?
Thanks heaps
Postby 93_Clubman » Mon Jun 27, 2011 12:09 pm
Has the timing been checked? Appreciate timing on NB8A is not as easily adjustable without a modification as NA6 & NA8, but might be worth a check.
Black miata
Postby Black miata » Tue Jun 28, 2011 4:49 pm
Thanks for that Clubman
I have had the whole engine pulled apart and everything looked at. Timing, Injectors,air fuel ratio etc etc and still can not find the issue.
I have been told that it is only at a certain rev range at around 60km/h.
Do you have any other ideas at all?
Postby 93_Clubman » Tue Jun 28, 2011 6:36 pm
Black miata wrote:When cruising at 60km/h well any speed and I lightly put the accelerator down there is a fast paced rattle coming from the engine.
Black miata wrote:I have been told that it is only at a certain rev range at around 60km/h.
Given the advice the noise seems to becoming from the engine, it would seem to rule out the heat shield for the headers, which commonly comes lose at one or more mounts, especially on NA6 & NA8. But seeing as all else so far has failed to identify the source of the noise, it would be worth checking the heat shield if this hasn't already been done, or if it hasn't already been removed. Heat sheilds at the catalytic convertor & the bullet muffler also rattle if they come lose, but they're further away from the motor.
Users browsing this forum: No registered users and 139 guests
