Davex3 wrote:NitroDann wrote:This still isnt right, read my post, it may be that 15psi on the stock turbo is the limit (yeah thats about right), but with water injection it might be 13 psi, a bigger turbo and water injection it might be 10 psi.
Dont just deal in absolutes with someone asking advice about his engine, if he throws a large frame garrett on there and boosts 15 psi with his new upgraded intercooler that is NOT the same as 15psi on a hot day from his stock turbo. Its much more.
I think you need to do some more research and quit speaking out your arse, either that or you fail to comprehend my post. 15psi+ will bend the stock rods with any turbo, not just the stock one. I also stated the power limit which the rods can handel relatively safely. You need to keep power below 200rwkw and 15psi to not bend the stock rods.
Do yourself a favor and go check mt.net
He could comprehend your post. He is just merely showing you how you are incorrect.
Not hugely incorrect but there is a lot more to the equation then you've said. Thats all he is pointing out.
So when you think about it theres no need to jump down his neck when he is trying to be helpful now is there?
It should also be noted that he has more training than " I READ IT ON THE INTERNET IM A MASTER NOW".
Have a good easter.
