NA6 Variable TPS Dramas
GAGE
Re: NA6 Variable TPS Dramas
Postby GAGE » Mon Dec 27, 2010 11:39 pm
Hi guys,
After much tinkering I found my issue! It appears that the green wire with the white trace is earthing somewhere between the ecu and tps. I've run a seperate wire between the two and its now reading just fine :D
Now I just need to figure out what is making it stall just off idle... does anyone have a map with good idle/startup for a Wolf 3D V4 that I can look at?
Thanks for all the assistance!
Kain
Postby Kain » Sun Jan 02, 2011 12:36 pm
Sorry to take this off-topic (but at least the initial problem has been sorted), but:
saboteur wrote:I used a BMW TPS on my NA6 and it would bolt up fine too, just in case you get stuck.
Where did you source that BMW TPS (and I'm guessing that the correct plug is required for it), and do you happen to have a part number handy?
Users browsing this forum: No registered users and 41 guests
