Overflowing coolant
Juffa
Overflowing coolant
Postby Juffa » Thu Jan 14, 2010 1:33 pm
Novice1 wrote:
saboteur wrote:Do the fans kick in when you are sitting in traffic etc?
No idea. I am led to believe that both fans are not always on and to do so would require engine management system to set parameters as to when and at what temperature both fans engage.
Cheers Novice1
Normally the air cond fan will only run when the air cond is on. It is possible to run both fans in parallel. I have done this on my NA.
http://forum.miata.net/vb/showthread.ph ... rallel+Fan
J
Novice1
Overflowing coolant
Postby Novice1 » Thu Jan 14, 2010 6:55 pm
93_Clubman wrote:
Novice1 wrote:I, am tempted to go with a different tuner, who says he can "unlock" my current tune. Starting to retune from scratch tho would be very costly and I have already spent a small fortune on tuning. Car has just had retune and its not as good as an early tune.
Ron, it sounds like you weren't able to resolve that locked ECU issue you had late last year?
Car is back. One new radiator cap, 1.3bar one. Boy am I a happy camper. Car goes in next wednesday to have ? autometer temperature gauge fitted, retune and not locked. Bonus is tuner is near to where I work and I won't be hijacked into using a particular tuner. They will have the car for 10 days as I am off to new zealand. Tuner reckons he can make my car much more driveable, meaning he reckons it runs like a dog:) Car is going to have haltech set parameters so that both fans come on at a particular temperature.
Who the hell would have thought that such an innocous thing as a radiator cap could cause so much grief.
Cheers Novice1
Overflowing coolant
Postby 93_Clubman » Fri Jan 15, 2010 12:27 am
Good to hear it was an easy fix & everything will soon be sorted.
Overflowing coolant
Postby Okibi » Fri Jan 15, 2010 1:32 am
Novice1 wrote:..Car goes in next wednesday to have ? autometer temperature gauge fitted..
http://mx5cartalk.com/forum/viewtopic.php?p=519131
You might not be able to get a group buy one in time but you might get one from Ocean at Chikara in the US or direct from Saiji at Maruha motors in Japan sent in time.
Steampunk
Overflowing coolant
Postby Steampunk » Fri Jan 15, 2010 12:47 pm
Novice1 wrote:They will have the car for 10 days as I am off to new zealand.
Pffft... they don't need 10 days to tune your car right.
Have you not seen what happened in Ferris Bueller's Day Off? :P
I have some space at my house that is just right for a grace green turbo MX-5 :wink: :mrgreen:
Novice1
Overflowing coolant
Postby Novice1 » Fri Jan 15, 2010 6:41 pm
Though your altruism moves me Andrew, I cannot remember seeing any space last time I looked in your garage.
By the way is their a run up glorious tonight?
Cheers Novice1
Novice1
Overflowing coolant
Postby Novice1 » Fri Jan 15, 2010 6:47 pm
The temp gauge I am getting fitted is $250 installed. At this point in time I just don't care if there is anything cheaper, better, stronger ...whatever. If, I lose a few dollars I lose a few dollars.
Cheers Novice1
TieNN89
Overflowing coolant
Postby TieNN89 » Fri Jan 15, 2010 8:39 pm
i got spares ;)
TieNN89
Overflowing coolant
Postby TieNN89 » Fri Jan 15, 2010 8:41 pm
Cheers Novice1
Novice1, Its not cheaper to go this way its to monitor the water flow coming out of the engine after the thermostat so you know when or does your thermostat work...
Its a neater way than cutting the radiator hose which would do the same thing or getting tapping it into the stock sensor (not sure if it is possible)
Overflowing coolant
Postby hks_kansei » Wed Jan 20, 2010 9:09 am
hmm, my car does the same coolant overflow thing.
glad I read this thread, looks like a new Rad cap for me!
Users browsing this forum: No registered users and 147 guests
