"Cool" heh.
Fair way out for the oil filter though. I got the same JetCo shielded air filter too
Heatshield
- SuperMazdaKart
- rossint
Heatshield
Yea, wanted the filter over the other side but no room for it with out moving some stuff about. It will eventually go to an oil cooler.
Heatshield
did you paint the cam cover blue or is that anodized
if its anodized where did you get it done (weigh less than paint i hear)
every ounce counts
- rossint
Heatshield
Painted by the guy who owned it before me.
Heatshield
Looks good and it is available at my local S/cheap, will it curve more or did you just want a straight kind of look when fitted? I was thinking it might look ok with a rolled effect as well.
- rossint
Heatshield
It can be shaped into just about anything you care to throw at it, look at the pic in the link:
http://www.aclperformance.com.au/prod_heatshield.htm
I just went for quick and easy.
Heatshield
MG Garage on ebay was the best way I found to buy it. They were good.
My extractors run fairly close to the firewall, all the heat issues I had were with wiring and ecu frying on the cabin side. A sheet of this rolled to fit between the pipes and the firewall finally fixed it.
- rossint
Heatshield
I've had a chance to get the car nice and hot and it's surprising how well this works, I haven't done any real measurements but just using my hand the induction pipeing and under bonnet temps feel noticably cooler.
Users browsing this forum: No registered users and 140 guests
