I should have marked the VVT cam, but the number of teeth on the belt between the two cams are right. Im not sure if ha I have to move it up or down one gear but will find out when I have time...
how are you able to tell?
there is no vertical marker on the intake camgear. Or at least its not visible as far as i can tell.
However the marker you do have, does not line up with the backing plate behind the camgears at about 4 O'clock it appears 1 tooth too far up where you have it secured with all the tools in the pic above.
again I've never put together the timing on a mx5 with VVT so I'm not certain.
