How many of you fine gentlemen use welded diffs?
rascal
Postby rascal » Fri Aug 21, 2009 1:31 pm
GP wrote:I've only ever seen welded diffs used on the dirt (speedway) On the road it would make any car handle bad and in the wet you would be sideways everywhere.
Welding a diff is not as easy as it sounds either, Have done a few for the speedway and found that they have to be machined so that when it's welded the axles are running true otherwise Kaboom :D
I've had several diffs welded and never had to machine any of them.. amd ran them on bitumen circuits for 10 years without issues.
As mentioned earlier it more depends on the quality of the welding as to whether they go bang or not..
dorifta
Postby dorifta » Fri Aug 21, 2009 2:56 pm
hrmmm still don't know what to do!
The nb (which i picked up yesterday!) is a stocka. So i thought id get some tyres/suspension/exhaust work before the driveline but went for a drive up to mt dandy last night and the diff was the biggest let down!
So i was thinking as a quick fix, CIG the diff n concentrate on other areas till i have a spare $1000 laying around for a 2 way!
get busy living or get busy dying
rascal
Postby rascal » Fri Aug 21, 2009 3:12 pm
FWIW, I wouldnt run a locked diff on the street.
Even ignoring safety issues, its an instant defect, and then you'll be up for the fine as well as buying an LSD anyway..
Besides, for a n/a motor, most of the wheelspin can be eliminated by suspension mods/adjustments as well as refinements to your driving style....
dorifta
Postby dorifta » Fri Aug 21, 2009 3:40 pm
i have got plenty of defects in my time!
yeah i guess ill start saving for either a 1.5 or 2 way
thanks for everyones input!
also if i may ask, whats the deal with this koni yellow and king combo every1 seems to be talking about? i was thinking about getting them BC racing coilovers:
viewtopic.php?f=18&t=37088&hilit=oil
GP
Postby GP » Fri Aug 21, 2009 4:10 pm
You don't understand, Read my post again
Graham
rascal
Postby rascal » Fri Aug 21, 2009 4:45 pm
ok, I read it again.....
Yours went bang cos the axles werent true rather than any welding deficiencies??
My comment still applies, I never machined any of mine and they didnt go bang..
Or am I still missing your point...
