Where to get low comp pistons?
CT
Postby CT » Fri Aug 21, 2009 10:52 am
The best pistons for MX5's are the Flyin Miata Wisecos - every time. They are differently designed than the catalogue wisecos and have been proven time and time again.:)
petross
Postby petross » Fri Aug 21, 2009 11:54 am
If i only want to be pulling 145-160kw, i wont need to put low comp pistons in will i?
I mean, the bottom end is reconditioned, ported head and cams, 2 1/4 inch extractors back, wolf v500 ECU, lightened flywheel. All done right. All i need now is a snail :D :D
Boags
Postby Boags » Fri Aug 21, 2009 5:08 pm
Good tuning is the key. Sean was running 15PSI on the standard engine with a good tune and it lasted a while. He then rebuilt with standard gear, except for rings, and ran 18PSI for a while.
It ended up eventually blowing up each time, but that's a lot more boost than you'd expect from the stock gear. :mrgreen: All in the tune.
petross
Postby petross » Fri Aug 21, 2009 6:01 pm
Theres no way i want to be running thats much unless i was racing hahaha
All i want is 10-12PSI so it wont blow and is reliable but with lots of power...
Do you know who tuned it?
hot rod
Postby hot rod » Fri Aug 21, 2009 7:57 pm
Try SPS in Dandenong, they've been around for a long time and soley make custom forged pistons for any application.
Special Piston Services
Address: Factory 13 112 Hammond Rd, Dandenong, VIC, 3175
Phone Number: (03) 97931110
lil red rocket
Postby lil red rocket » Wed Aug 26, 2009 2:45 pm
Try
James at Belfab Racing Products Las Vegas [mailto:sales@belfabracing.com]
The kit I bought was for a Turbo 1600 MX5 making about 200 RWHP at 8-10lb of boost
Mazda Miata 1.6 and 1.8 HP Engine kit
- Comp Ratio 8.6:1
- Exhaust Valve Size 1.6L 26.20x5.94x105.35mm /Nitrided/ Stk size (1100)
- Gasket Set 1.6L B6D
- Intake Valve 1.6L 31x5.96x105.35mm/Nitrided/Stk. size (1100)
- Main 10 over
- Forged Piston Bore 79.00mm
- Forged H Beam Rod 10 over
- Valve Spring Dual Springs 74lbs@34.2mm
All the above goodies were about Aus$2300 landed
The head gasket was crap - we used a multilayer steel
[color=#BF00FF]I like it! I like it a LOT!
http://www.cardomain.com/ride/3368773/3
