Beatrush 'Brass' Gear Selector Bush ??
Postby Okibi » Tue Feb 03, 2009 7:12 pm
mx5 brass bush for gear shifter
Postby Regie » Tue Feb 03, 2009 9:33 pm
lets get another group buy happening. my one is goone
Postby sliq » Tue Feb 03, 2009 9:40 pm
gather more interest and i'll be happy to set one up :mrgreen:
madboy
Postby madboy » Wed Feb 04, 2009 9:09 am
sliq wrote:gather more interest and i'll be happy to set one up :mrgreen:
what are the benifits and how much are they lilkely to be? Will it help smooth out my chunky 2-3 gear change?
sorry about going off topic...
Postby sliq » Wed Feb 04, 2009 9:13 am
from the sounds of things, that doesn't sound like a bush problem. i think your 2nd gear synchro could be rooted :idea: basically, if you have problems putting the car into gear e.g. selecting the reverse gear and the gear does not select, that ought to be the gear selector bush.
Fuzzlet
Postby Fuzzlet » Wed Feb 04, 2009 12:43 pm
sliq wrote:from the sounds of things, that doesn't sound like a bush problem. i think your 2nd gear synchro could be rooted :idea: basically, if you have problems putting the car into gear e.g. selecting the reverse gear and the gear does not select, that ought to be the gear selector bush.
My reverse does this....car only has 35k kms on it.....it did it when I bought it with 22k on it aswel...
Postby sliq » Wed Feb 04, 2009 1:47 pm
Fuzzlet wrote:My reverse does this....car only has 35k kms on it.....it did it when I bought it with 22k on it aswel...
mine did too. had to put the car in first, roll it forward a bit, then reselect reverse :?
Fuzzlet
Postby Fuzzlet » Thu Feb 05, 2009 11:37 pm
Yep exactly what I have to do...sounds like it may be a common fault then...
