Small rattle / violent vibrations (2 seperate problems)
crzymx
Postby crzymx » Sat Nov 15, 2008 1:20 am
Garry wrote:The "cricket" sound could be coming from a dry joint where the rod from clutch slave cylinder pushes against the clutch throw out arm. Classic symptoms are a chirping type noise that goes away with very light pressure on the clutch pedal. 5 minute fix:- get under the car, push the the rod from the slave cylinder back into the cylinder a little bit, apply grease to the now exposed rod/throw out arm joint, pump clutch, start engine, enjoy the peace and quiet of your handy work.
Much cheaper and easier than replacing the clutch.
If that doesn't fix your problem then you'll need to delve deeper into the clutch mechanism, but I'd try that first.
I get the noise whilst accelerating with the clutch engaged only. Not when its rolling, not when its reving in neutral. Do you think its the clutch bearing?
DIY is the new black!
Garry
Postby Garry » Sat Nov 15, 2008 8:59 pm
No idea. If the clutch rod joint is dry you can usually hear the cricket sound with the clutch out and the car not moving. Very light pressure on the clutch pedal will make it stop. But you could hear it on my NA8 when driving close to a concrete jersey barrier with the roof down. It sounds like your problem could be a bit more sinister. :frown:
crzymx
Postby crzymx » Sat Nov 15, 2008 11:14 pm
Hope not! Do you think its the clutch bearing? i really have no idea about any technical terms so please excuse me
feel_ixx
Postby feel_ixx » Mon Nov 17, 2008 5:00 pm
well i tried lithium greasing my clutch slave cylinder thingy, took a while for me to locate it haha but no luck there. Its getting installed as we speak, and its not a Mazda OEM clutch, its actually an Exedy clutch. Yay for me I guess haha
- Felix
Garry
Postby Garry » Tue Nov 18, 2008 8:17 am
Oh well, pity it didn't work. It was worth a try, it may have saved you some $$
Benny
Postby Benny » Tue Nov 18, 2008 12:24 pm
Some of the problem that leads to clutch shudder is that the clutch face becomes a bit glazed.
Try doing a hard start while slipping the clutch, and that should grind a little of the glazing off the surface and hopefully it won't shudder for a while or at least it won't shudder as badly.
Repeat as neccessary, and call me in the morning.
feel_ixx
Postby feel_ixx » Tue Nov 18, 2008 1:07 pm
ah thats a shame, my car is already at the mechanics pick up at about 6pm tonight :(
- Felix
crzymx
Postby crzymx » Tue Nov 18, 2008 3:07 pm
What do you mean by hard start and slipping the clutch?
philz
Wheel guru
Postby philz » Tue Nov 18, 2008 3:15 pm
Slipping clutch also means feathering the clutch.
AJ
Postby AJ » Tue Nov 18, 2008 4:51 pm
philz wrote:Slipping clutch also means feathering the clutch.
& "riding the clutch", an easy way to burn some crap off the clutch plate as Benny said..............use 2nd gear & really pile some revs on from a standing start & ride the clutch hard........should strip any glazing off.
XMX5 Rogues
bensale
Postby bensale » Tue Nov 18, 2008 5:29 pm
AJ wrote:& "riding the clutch", an easy way to burn some crap off the clutch plate as Benny said..............use 2nd gear & really pile some revs on from a standing start & ride the clutch hard........should strip any glazing off.
Don't forget to enjoy that really tasty smell afterwards.... This works wonders, completely remeoves the shudded if it is indeed glazed.
www.othersideproductions.com
Postby sliq » Tue Nov 18, 2008 5:34 pm
bensale wrote:
AJ wrote:Don't forget to enjoy that really tasty smell afterwards.... This works wonders, completely remeoves the shudded if it is indeed glazed.
yes, you get complimentary fried clutch.. :lol:
feel_ixx
Postby feel_ixx » Tue Nov 18, 2008 6:08 pm
CFC for short.
- Felix
crzymx
Postby crzymx » Tue Nov 18, 2008 11:54 pm
So by riding the clutch you mean positioning the clutch so it is kind of half engaged hald disengaged?
AJ
Postby AJ » Wed Nov 19, 2008 5:33 am
crzymx wrote:So by riding the clutch you mean positioning the clutch so it is kind of half engaged hald disengaged?
that's why I said to use 2nd gear from a standing start, saves having to explain it, you'll know what we mean when you try it :)
XMX5 Rogues
