inlet filters systems
Postby sliq » Wed Oct 15, 2008 10:41 pm
wun911 wrote:nice real short less weight are you getting more responsiveness because you have moved the air flow sensor?
what rad is that btw? any good?
lol that's correct wun, less weight! i'm not too sure on the reason why the car is more responsive - but as you suggested, because the tuned length of the intake has shortened bringing the air flow sensor closer to the engine, that might be it.
the radiator is a cooling pro one. its been good (so far), no dramas at all.. caffeine did most (actually, all :oops: ) of the installation and it was a stroll through the park. no overheating dramas. if anything, i've noticed the needle on the gauge drop a tincy bit. apart from that, it's good bling for the bay, and was looking to replace the crappy oem one because the top tank was getting light brown.
