URGENT: Does this Flywheel need machining??
AJ
Postby AJ » Fri Jul 11, 2008 9:39 pm
when it comes to clutch replacement Minh, too many cooks bugger the soup.................you should be fine with two other pairs of hands 8)
XMX5 Rogues
Postby fastfreddygassit » Fri Jul 11, 2008 10:14 pm
Minh, if you already haven't, please have a read of the descriptions of the 2 clutch installs we have done.
Didn't have a hoist but used the pit at my parents place.
Fastfreddy's install...took a bit of time
and
Fatty's NA6 install - the second time- but not much faster
Just remember...there are 11 bolts holding the gearbox to the engine. Numbber 11 is a pia :shock:
enjoy :mrgreen:
Mr Starlet
Postby Mr Starlet » Fri Jul 11, 2008 10:22 pm
This is what it looks like on trial fit; flywheel, Exedy standard 1.8 clutch (MDZ052U), matching pressure plate, screw are hand tight.
This will sound very dump for those whose been there before but, is there suppose to be this 5mm grab in between pressure plate and flywheel :S? is this normal? will it come down nicely when torqued up?
Fabio
Postby Fabio » Fri Jul 11, 2008 10:59 pm
Yes this is normal. the last bit of tightening compresses the spring, so the bolts will be tight to do up, but with out it, your clutch would slip.
Mr Starlet
Postby Mr Starlet » Fri Jul 11, 2008 11:10 pm
Fabio wrote:Yes this is normal. the last bit of tightening compresses the spring, so the bolts will be tight to do up, but with out it, your clutch would slip.
Thanks for the confirmation Fabio :) .
wun911
Postby wun911 » Sat Jul 12, 2008 11:32 am
Machine a flywheel is it like the same as machine a rotor? Is there a minimum thickness for a flywheel? A flywheel isnt a heat sink so I guess you could shave more off? (searched but cant find)
every ounce counts
Mr Starlet
Postby Mr Starlet » Mon Jul 14, 2008 3:19 pm
Flywheel and clutch installed...
http://picasaweb.google.com/s363134/Dod ... xnOnfMGJDY
..took the opportunity to install some polyurethane bushings as well.
