ducktape69 wrote:also using castol edge sport 5w30 ...ive used pretty much all oils under $100....this is definately the best ive used....
oil/filter changes every 7500km.
i thought the recommended change for oil and filter was every 5000kms?
jcs86 wrote:Anyone here use any of the Penrite oils??
Novice1 wrote:I, use Castrol Edge 5W-30W in a turbo NB.
A couple of people have told me I should use a heavier oil, is this correct. And if so what?
Cheers Novice1
GP wrote:Mobil Synth S 10W-40
I wouldn't use 5w-30 in the Australian climate and full synth isn't necessary in my old na
MX5CHIC wrote:I used to use Mobil 1 but then discovered that they now use Mineral Oil base stock in it, makes me feel a little ripped off when I thought I was paying all those dollars for a "100% Synthetic".
I have now changed to Nulon Synthetic and have noticed engine noise has reduced, I also just drained my Power Steering after it developed a concerning noise and filled with Nulon Synthetic - noise is gone.
For my future oil change I will be sourcing AMSOIL which I used to use when I raced bikes ... best oil on the market.
zawrilla wrote:Elf Excellium 10w 50.
Quite happy with it, but nothing to compare to since it's the only oil change I've done on the car. Might change to something else or just keep going with it.
