max boost for 10:1 motor
- sprx3
- Russellb
- RIP Nov 2014
Well After the Rebuild the Engine came out at 9.9:1 comp
was after 10:1 but its close enough
got it in the car today and It started on the first turn of the Key ( after fixing the busterd injector ORING . Hope to have it on the Dyno on Wednesday night then off to Bathurst
Will post Dyno results when its done
Heres hoping for 200+ on 14 PSI
My ClubmanRebuild
MX5 SE Rally car is HERE
- Russellb
- RIP Nov 2014
Well the Engine made 190KW ATRW on 12.5 PSI of Boost.
ther was mopre init but the boost controler was having problrms over 13 PSI ..
Want to go to 20 but his will have to wait
My ClubmanRebuild
- Russellb
- RIP Nov 2014
drifter wrote:Nice tune![]()
20psi
With te New Hbeam Rods and Wiseco pistons It will take it. did a run with no actuator and the boost was stuiped we stoped a 20 psi @ 5000rpm and it was over 200KW so with control of boost 250 KW will be easy
My ClubmanRebuild
- Russellb
- RIP Nov 2014
Pistons and rods from the states were just under $1000 landed
over sized vales $430 a set landed
valve springs $500
al aprox $$$$
Gaskets $390
everything else FREE
valve springs $500
al aprox $$$$
Gaskets $390
My ClubmanRebuild
- 16bit
sweet so this kit should pretty much cover it all.
http://www.belfabracing.com/product_inf ... 7acf5bc994
what do you think labour would be for the non engine builder amoungst us?
