NB RUnning Poorly...any ideas?
Steampunk
Postby Steampunk » Thu Jan 17, 2008 7:36 pm
Thank you master Yoda. This young Padawan thanks you, and from now on I will be mindful of the future, but not at the expense of the present. 8)
Craig
Postby Craig » Thu Jan 17, 2008 8:31 pm
I'm not Yoda, I'm Two-Hump Kenobi! :lol: :shock:
*waves hand Jedi style*
You really want a blue car! :P
Steampunk
Postby Steampunk » Thu Jan 17, 2008 9:03 pm
:shock: I reeeally want a bluuue carrr .... :shock:
marcusus
Postby marcusus » Thu Jan 17, 2008 11:40 pm
Foolish humans and their vulnerability to camel mind tricks...
(PS Craig, tell people to buy more cars off you whilst waving your hand in an odd fashion :P )
Tezzax5
Postby Tezzax5 » Fri Jan 18, 2008 8:21 am
Does it include changing hands at a hundred..... :lol:
ONLY Joking Craig..... :mrgreen:
Postby bruce » Fri Jan 18, 2008 1:51 pm
Craig, stop moving your hand in a back and forth motion !
hamish71
Postby hamish71 » Fri Jan 18, 2008 4:03 pm
Right...the early NB8B's that had the shuddering clutches replaced are prone to this error as the neutral switches wiring is clipped to the under chassis of the car, and when the clutches are replaced the dealers just cut the ties and never bother to replace them, which in time leads to the wire breaking internally from vibration and fatigue.
Now...what happens is the car thinks you just sitting there stationary and revving the crap out of your car, and not actually in gear, hence it never actually uses the readings from the O2 sensor and it drives like sh*t until it warms up and goes into a default setting.
Craig
P.S. I'll type up a novel next time perhaps or maybe you can just trust me!
Thankyou. I shall try that...dont suppose the sequel to your novel would describe how to replace it?
hamish71
Postby hamish71 » Fri Jan 18, 2008 4:05 pm
I can also say, its not the spark plug leads (changed), and I dont think its the coils. (Had them checked today....but to be honest, all the guy could tell me was, they are both the same! He was from scrorcher distributors here in Melbourne, recommended above. His test equipment said they are both under voltage, but he made it clear that his equipment was not the right thing to be using. All he could say was, they are both exactly the same!)
Nickers
Postby Nickers » Fri Jan 18, 2008 4:41 pm
Hmmm, sounds exactly like the problem I've been having for the last 6 months. Mine runs rich on startup, exhibits the same symptoms and clears up with a bit of temperature in it. Same stall problem on idle too. I've tried another ECU and coolant temp sensor, with no change.
Any chance this gearbox neutral switch doover is used on the NA6?
1990 Red NA6
Craig
Postby Craig » Tue Jan 22, 2008 12:47 am
Tezzax5 wrote:(PS Craig, tell people to buy more cars off you whilst waving your hand in an odd fashion :P )
:lol: :shock:
Craig
Postby Craig » Tue Jan 22, 2008 12:49 am
hamish71 wrote:Thankyou. I shall try that...dont suppose the sequel to your novel would describe how to replace it?
I'm told its a shitter of a job as it's on top of the gearbox. :shock:
hamish71
Postby hamish71 » Sat Jan 26, 2008 3:08 pm
RIght, I have changed a shitload of things, and ven verified that the timing had jumped a tooth, and was thus out...but still...not quite right....
JBT
Postby JBT » Sat Jan 26, 2008 4:09 pm
How could the belt jump a tooth? Not possible if the tensioner is set right. Unfortunately, it sounds like a poor belt replacement job. :frown:
So you've fixed that and it still isn't right? Checked the timing to see if the crankshaft pulley has moved?
hamish71
Postby hamish71 » Wed Jan 30, 2008 8:43 am
crankshaft pulley and key are in perfect working order....
What are the chances the cat is screwed, thus restricting exit of exhaust gases????
JBT
Postby JBT » Wed Jan 30, 2008 11:17 am
hamish71 wrote:What are the chances the cat is screwed?
Very little at 150,000km. I've seen MX-5s with 200,000+km on the original exhaust and all OK.
