The new radiator has arrived - PICS
Tezzax5
Postby Tezzax5 » Fri Jan 04, 2008 5:45 pm
Just a thinking out loud question...Does anybodies pwr radiator fit without hacking?
I thinking for the money i might get a quote from Kavey located in maroochydore to get one built...
opinions please
Terry S
lowmiata
Postby lowmiata » Fri Jan 04, 2008 5:50 pm
Tezzax5 wrote:Just a thinking out loud question...Does anybodies pwr radiator fit without hacking?
opinions please
Terry S
I used an M3 sized cor I think it was exact dimensions are 640x340
obviously the PWR is slightly bigger as i had no dramas at all!
EVI15 1998 to 2008
Tezzax5
Postby Tezzax5 » Fri Jan 04, 2008 6:09 pm
timk
Postby timk » Fri Jan 04, 2008 11:20 pm
1red5 wrote:Too much work for me. Begs the question, what template did they actually use to make the radiator. :?
My PWR radiator was about the same amount of work, maybe Koyo are better?
Steampunk
Postby Steampunk » Sat Jan 05, 2008 7:43 am
For the prices the PWR is charging, you shouldn't do ANY work on it. Think about it, how can they get most of the holes correct and stuff up a few?
It may be excusable for a manufacturer who sells many different things, but PWR is a specialist.... would you be pissed off if BBS made wheels with one hole, out of four, out of alignment?
Postby Okibi » Sat Jan 05, 2008 1:53 pm
Yup I agree,
But I don't think they do large enough volumes.
I think they measure up each one rather than having a jig set up for each type of car or perhaps they've bent their jig.
Muzdaman
Postby Muzdaman » Tue Jan 22, 2008 7:59 am
Has anyone tried the PWR radiators that have an attached oil cooler?
Postby Okibi » Tue Jan 22, 2008 10:19 am
Well it's not a plug and play fit ..
Muzdaman
Postby Muzdaman » Tue Jan 22, 2008 12:48 pm
Do you know if it is any wider than the other PWR's or if the radiator is smaller to fit the oil cooler alongside?
What were the biggest hassles getting it to fit? Can you remember how much it was?
Im guessing maybe a seperate oil cooler would be simpler.
Thanks
Postby Okibi » Tue Jan 22, 2008 1:00 pm
It fits in the stock location hence the radiator is not as wide as OEM to accommodate the room the oil cooler takes up.
Biggest hassle was getting the stock fans to fit, it slotted into the OEM spot just fine.
How much? too much .. but still cheaper to get via the states than via PWR directly. :roll:
Muzdaman
Postby Muzdaman » Tue Jan 22, 2008 2:13 pm
A few friends were trying to get PWR radiators for there ATVs. same story, heaps cheaper from the US.
Would you make the same decision again or would you get a seperate oil cooler??
what website did you go through???
Thanks
Postby Okibi » Tue Jan 22, 2008 2:39 pm
I think i'd get one custom built next time. For now the design and reasons will stay locked away in my brain.
Postby Okibi » Tue Jan 22, 2008 2:43 pm
I guess that doesn't really answer your questions..
I like the fact the oil cooler is part of the radiator, its a lot neater solution.
I'd probably prefer it to a PWR radiator and PWR oil cooler separately mounted.
I got it from the fantastic people at FlyinMiata.
Muzdaman
Postby Muzdaman » Tue Jan 22, 2008 4:23 pm
Last question, maybe?
Is it a 40mm or 55 mm core?? Or something else?
Thanks for the help. Im seriously sonsidering this, just the price that turns me off.
