NB8A oxygen sensor
Garry
Postby Garry » Mon Dec 24, 2007 9:14 am
But did you blow though the top port to check to see if it was leaking? If it wasn't leaking then it wont solve your problem
EGG80X
Postby EGG80X » Mon Dec 24, 2007 9:31 am
Garry wrote:But did you blow though the top port to check to see if it was leaking? If it wasn't leaking then it wont solve your problem
yeh i did...... there is a very minor leak :frown: :cry:
Garry is there a website where you purchase the EGR valve?
Garry
Postby Garry » Mon Dec 24, 2007 9:43 am
Yes, mine had a minor leak too, from the stem of the valve out around the spring area.
I got a used one from Mania for $100. It was a bit dirty but didn't leak.
I think you can get them from Trusville Mazda in the US or similar who advertise on the Miatanet site. They are about $US125 plus the usual $9787675434 shipping charge.
sprx3
Postby sprx3 » Mon Dec 24, 2007 12:29 pm
if anyone does need a direct replacement 02 for the nb the denso part number is 234-4235 & can be landed for under $200 A.U from the states, if you need more info I can give you details of where i got mine from.... You can also get the same sensor cheaper alot without the plug........
zoran
want to join the mazda car club of australia?, for more info please p.m me
EGG80X
Postby EGG80X » Mon Jan 21, 2008 7:40 pm
ahh finally block the EGR and the idle went away!!!
still got this problem of having a flat spot between 1000-3000 rpm
Postby Okibi » Mon Jan 21, 2008 8:38 pm
EGG80X wrote:...still got this problem of having a flat spot between 1000-3000 rpm
me too, figured that was factory fitted :(
