Mazdaspeed Engine Mounts
Brad
Postby Brad » Mon Oct 15, 2007 7:38 pm
I've got these, well the ones Mania supply. Imperceptible extra NVH IMHO. Mine were both shot, one came out in two pieces.
Andrew
Postby Andrew » Mon Oct 15, 2007 7:45 pm
JBT wrote:Helped with an engine change on an NB8A on Friday/Saturday. Both mounts were stuffed but there was no visual or other indications until the engine came out.
How many Km's on the car :?:
JBT
Postby JBT » Mon Oct 15, 2007 8:54 pm
185,000 km.
Brad
Postby Brad » Mon Oct 15, 2007 9:10 pm
Mine went at 145.
Babalouie
godfather of saké
Postby Babalouie » Mon Oct 15, 2007 9:14 pm
Mine were already gone by 110,000.
Andrew
Postby Andrew » Mon Oct 15, 2007 9:23 pm
How hard is it to replace them :?:
JBT
Postby JBT » Mon Oct 15, 2007 9:29 pm
With the engine out it is a doddle. If the engine isn't coming out, it (and the gearbox) will have to be lifted quite a bit to get them out. It may mean removing a lot of the stuff that has to be removed for engine removal.
Maybe someone else has experience.
Bevan
Postby Bevan » Mon Oct 15, 2007 9:30 pm
Andrew wrote:How hard is it to replace them :?:
I was just thinking about that one. Would it be as easy as giving yourself a clear path to the mounts, then supporting the engine evenly with a couple of jacks, or an engine crane, and replacing the mounts one by one?
JBT
Postby JBT » Mon Oct 15, 2007 9:33 pm
Bevan wrote:Would it be as easy as giving yourself a clear path to the mounts....?
See my post above. :(
Babalouie
godfather of saké
Postby Babalouie » Mon Oct 15, 2007 9:50 pm
I think one side is a bit tough.
IIRC the passenger side goes in first. At this point the engine is at an angle.
Then you lower the driver's side, which has a slotted hole so that the bolt from the mount can just slide in. But I think the slot isn't quite long enough so you have to manhandle it a bit.
Brad
Postby Brad » Mon Oct 15, 2007 10:36 pm
I did mine, with some help from Neil, in about 3 hours. It was quite fiddly, especially lining the stud up with the hole. Used a trolley jack under the engine and didn't have to remove anything.
JBT
Postby JBT » Mon Oct 15, 2007 10:44 pm
Beware about distorting the radiator hoses as the engine is moved and be careful not to crush the coil pack against the firewall. I think it would also be wise to remove the induction trunk to avoid damage.
Garry
Postby Garry » Tue Oct 16, 2007 9:32 am
If Mazda uses them in a production car I dont think there will be an issue for me with NVH.
I had a creaking noise every time I started off in first or second. I thought it was the PPF bolts because the noise was coming from that area. It progressively got worse and I got Mania to look at it on Saturday and they found that the PPF was cracked at the front diff bolt. I got David to check the engine mounts and both were cracked. I guess the loose engine mounts over time were putting to much stress on the PPF and it eventually died.
To check the mounts David just levered the engine up off the cross member a little and the cracks in the rubber were obvious. Reading Miatanet and talking to David broken mounts are quite common especially in FI cars. The passenger side usually dies first apparently.
My car has 120k km on it and I had suspected that something was up for a while, not just because of the creaking but because the car feels really doey letting out the clutch, a bit like winding up a rubber band before anything happens.
David said the mounts are easy to replace. He would have done it on Saturday afternoon while he was replacing the PPF if they'd had some in stock. They are doing it on Wednesday afternoon after work so it doesn't sound like a big job if you have a workshop full of tools and a hoist.
Prices are on the Mania website.
Bevan
Postby Bevan » Tue Oct 16, 2007 11:03 am
Garry wrote:Prices are on the Mania website.
Only $50 each for the genuine SE ones. Are there only 2?
Garry
Postby Garry » Tue Oct 16, 2007 11:05 am
Yeap, unless you want to replace the diff ones too. But I think you need to remove the diff to do them.
