SP Exhaust Leak, How to fix :)
blackster
Postby blackster » Tue Sep 25, 2007 8:23 pm
Boags'MX5 wrote:
blackster wrote:
jules wrote:C'mon Blackster, have a go. Goals open :lol: :lol:
Jules
There's no need to, the SP owners know how the SE performed on the day.
Yes, the scoreboard usually says it all for you. Was that the day you made 150ish rwkw?
Boags
If I was to answer that question, I for see this thread ending in another SE/SP battle. The thread wasnt intended about my car or the SE, if you would like to know how my car ran feel free to PM or start a thread elsewhere.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Boags
Postby Boags » Tue Sep 25, 2007 8:50 pm
Better yet, I'll search for the old one! :D
jules
Guitar Hero
Postby jules » Tue Sep 25, 2007 9:07 pm
I've seen the dyno result.
Didn't you start selling off all your development parts after that, and settle for a setup that was a bit more \"linear\"?
Jules
blackster
Postby blackster » Tue Sep 25, 2007 9:39 pm
edit.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Sean
Postby Sean » Wed Sep 26, 2007 11:41 pm
Dave wrote:
CT wrote:Are the inconel nuts and longer studs OEM update parts or as I suspect aftermarket? Where did they source the inconel nuts from?
CT, I sourced a supply of 8x1.25 inconel studs for Daniel/ Mania from a bolt supplier in Penrith (Spinners); however they couldn't supply inconel nuts (doesn't sound like they are too common?). They did supply some deformed nuts that have been brilliant on my turbo housing have not lost one yet (originals were just temporary residents - regularly heard them bouncing under the car...).
Dave
I had some troubles with studs falling out in the manifold to turbo juncture on my AVO setup. A set of inconel studs and deformed nuts (both from Tyrone - Drift Fury) fixed the problem right up.
Blue94t
Postby Blue94t » Thu Sep 27, 2007 9:49 am
I reckon I could do with a set of those Inconel studs. Whats the best way to contact Tyrone?
Also Sean, did you run a gasket between the turbo and the manifold. I haven't been after a couple of failures.
Jake
Marador
Postby Marador » Thu Sep 27, 2007 9:52 am
Ive just been given my SP back from mazda yesterday afternoon. I was hearing some metal on metal grind when i loaded the engine... thankfully mine turned out to be a similar problem... well... partially...
The bolts on the exhaust man where loose... the exhaust connection to the turbo was loose... and the heat shield ive got was griding up against the wastegate.
When spy has done a few k's on these new bolts ill be keen to see how its going and potentially get a set myself...
Silver SP
sabretooth
Postby sabretooth » Thu Sep 27, 2007 12:26 pm
What exactly is an inconel stud?
When doing my turbo manifold, I just used what seemed to be \"ordinary\" high tensile studs.
CT
Postby CT » Thu Sep 27, 2007 1:38 pm
Inconel is a particular material known for high heat tolerance. It may expand/contract/stretch less than regular high tensile materials - not really sure but it gets mentioned a lot around high heat sources. Hopefully Tyrone will chime in.......
jules
Guitar Hero
Postby jules » Thu Sep 27, 2007 1:39 pm
I believe they are a fancy alloy used in the space shuttle, so should be good for SP's :mrgreen: :mrgreen:
Jules
jules
Guitar Hero
Postby jules » Thu Sep 27, 2007 1:43 pm
AJ
Postby AJ » Thu Sep 27, 2007 6:36 pm
CT wrote:Inconel is a particular material known for high heat tolerance...
thank god, i thought it was one of those nappy things you old blokes have to wear :lol:
XMX5 Rogues
Sean
Postby Sean » Thu Sep 27, 2007 10:19 pm
Blue94t wrote:I reckon I could do with a set of those Inconel studs. Whats the best way to contact Tyrone?
Also Sean, did you run a gasket between the turbo and the manifold. I haven't been a couple of failures.
Jake
Tyrone is MX5_Drift_Furey on these forum, try PMing him, he is a fairly busy guy though so it may take a while for him to get back to you.
I used to run a genuine garrett gasket, but blew 3 of them out. Got tha manifold and turbo machined flat (just to be safe) and re assembled with no gasket, never had a problem since.
Locutus
Re: SP Exhaust Leak, How to fix :)
Postby Locutus » Wed Jul 08, 2015 1:06 am
I think I have a similar problem. How are these holding up 8 years down the track?
