We're running 86 mm pistons in sleeves
Sean wrote:Depends... If you just want to stab 200kw on teh dyno, then drive it daily you wont have an issue on s tock engine, it has been done by at least 2 forum members, but if you want to have 200kw and use all 200kw regularly you are not going to be keeping stock engines long.
marcusus wrote:Sean wrote:Depends... If you just want to stab 200kw on teh dyno, then drive it daily you wont have an issue on s tock engine, it has been done by at least 2 forum members, but if you want to have 200kw and use all 200kw regularly you are not going to be keeping stock engines long.
??? Can you elaborate on how this was done? It doesn't sound plausible to me, but I'm happy to be corrected.
Sean wrote:Car 1
AVO manifold, gt2871R (had small front housing not the 4 inch one), 540cc injectors, walbro pump, AVO cooler pipes, custom cooler, custom dump pipe microtech ecu, extrudehoned intake manifold, stock head/bottom end.
Car 2
AVO manifold, Garrett T28 based turbo (cannot be sure of exact specs but internal gat T28 flange, big 0.7 ar front, .86 rear) 600cc injectors, link plus, custom dump pipe, AVO cooler and pipes, all stock internal head and bottom end.
marcusus wrote:Sean wrote:Car 1
Car 2
Right, so they weren't really what I'd consider a stock engine. Although the engines themselves were stock, modifications had been done to increase performance.
Was starting to wonder whether it was possible to have (my definition of) a stock engine pulling that much power...
