/me runs away
ampz wrote:I would hazard a guess that maybe (depending on where the cuts to your harness where made) there has been a wire either crossed or the ground is somehow not enough of a short circuit now.
A vacuum leak (to answer your earlier post) can be any vacuum hose loose or unplugged causing erratic idle.
I hope you didn't fry your ignitor as they are quite fragile and the source of that rpm signal your diagram shows... That pin is only a 1V supply to your Tacho (via the ignitor) so seeing a 12V spike (just with the ground disconnected, the ECU may have hunted for a ground via the Tacho, maybe).
bruce wrote:Howabout disconnecting the battery overnight? (Not sure if that's any better than 90 mins though???)
