rhysk
Postby rhysk » Thu Sep 13, 2007 10:12 pm
Lukus wrote:But by the sounds of things, the application you used them for was probably wrong. HPS was probably more what you needed. They are more intended for street driving with occasional track work, rather than track work with occasional street driving which the HP Plus is designed for.
I agree with you 100%. Unless you're swapping pads for the track, the HP+ is the wrong pad. I didn't drive the car enough to justify swapping the pads.
Lukus wrote:Exactly what Endless range are you running?
CC-X.
bjones
- Vehicle: ND - 2
Postby bjones » Sun Sep 23, 2007 1:31 am
CT wrote:www.bsmsport.com.au for Ferodo
www.flyinmiata.net for Porterfields or Hawks
Alternatively, take the plunge and start a relationship with Flyin Miata. They are a little dearer than some of the other online guys, but I generally order on Monday and pickup at the post office here in Sydney on Friday if they have them in stock. Always excellent customer service.
Gday CT cant agree more with the customer service from the boys at FM(and the ladies) I called them on a tuesday morning our time ordered a set of rods and pistons and they where expressed to my door in under 24hrs NOW THAT's SERVICE
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
RobbieRat
Postby RobbieRat » Mon Sep 24, 2007 6:57 pm
Has anybody found an after market source for the anti rattle clips on the NB8B
Garry, the Hawk HP come with clips from Mania?
If thats any help.
Cheers Rob
Garry
Postby Garry » Tue Sep 25, 2007 5:34 pm
Thats good to know. Thanks for that RobbieRat.
Caffeine
Postby Caffeine » Fri Oct 12, 2007 12:03 pm
Garry wrote:Has anybody found an after market source for the anti rattle clips on the NB8B.
www.miatamania.com$6.50 US per corner. They have a nice exploded diagram of the brake assembly so it makes buying the right bits easy. Our cars are equivalent to the US hard suspension model
Garry
Postby Garry » Fri Oct 12, 2007 1:21 pm
Cool Caffeine, I can see the fronts listed but no rears. Am I blind or are they hidden away there somewhere?
Caffeine
Postby Caffeine » Fri Oct 12, 2007 3:05 pm
Garry wrote:Cool Caffeine, I can see the fronts listed but no rears. Am I blind or are they hidden away there somewhere?
They are there, they are the same part for the standard suspension, so it doesn't list a hard suspension version.
I have a set somewhere between here and the US, I'll let you know how they go when I get them finally!
Caffeine
Postby Caffeine » Wed Oct 17, 2007 5:26 pm
The clips arrived today, I'll try and fit them and let you know how they go...
Caffeine
Postby Caffeine » Wed Oct 17, 2007 10:25 pm
The good news is it looks like I've got enough for 2 cars!
The bad news is the rears don't look right...
Garry
Postby Garry » Thu Oct 18, 2007 10:28 am
If you have an extra sets of fronts I'll take a set off you.
bugga
ASE05
Postby ASE05 » Thu Nov 01, 2007 2:03 pm
Just got a price of $440/front set for the Ferodo DS2500
Anyone tried/heard of Mintex Xtreme? $300/front set sounds a lil' more reasonable but I can't find too much info on 'em.
Sorry for the hi-jack
Sing that song, puff all night long.......
Steampunk
Postby Steampunk » Thu Nov 01, 2007 3:45 pm
Anyone keen on a group buy for Hawk HPS? These are supposed to be a more road-friendly/rotor-friendly version of HP+.
I have written to a few suppliers in the US, the best I have gotten was (USD) $98 for Front AND Rear plus $50 shipping. That equates to approx $165.00 AUD for a full set.
I have an NA8 but prices for NB's are only a few dollars difference.
I've scoured numerous US Miata forums and they have had pretty good referrals .....
I'm not really putting my hand up to organise this, just wanted to put my 2cents in to give options, but I would happily get the ball rolling by contacting the supplier.
Hellmun
- Vehicle: NB8B - Turbo
Postby Hellmun » Sun Nov 25, 2007 8:26 pm
The sports upgrade package on NB8B's barely fits in a few 15' rims(it plain won't fit in RPF-1's and a few other 15's). I think I have about 2mm clearance on my track 15' rims. I don't think you'd be able to get those calipers under a normal 14' rim.
Personally I'm thinking about putting ultimates in as a street pad with my standard rotors. Then getting a set of DBA4000's and DS3000/ Hawk blues for the track on the front. Can't lock the semi's when hot atm...so think I can push for a little more brake friction.
meanmx
Postby meanmx » Sun Nov 25, 2007 9:01 pm
The NB8B brakes are a massive 40mm bigger than the NA6 brakes and as pointed out above some 15's wont fit over it. If you upgrade to the NA8 brakes though you should be right. To upgrade to the NA8 you need brackets, rotors and pads?, although it should be noted that the NA8 caliper is a little larger although you can continue to use the NA6 calipers if you prefer. Jumping up to the NB8B brakes you will need the above and judging by the size diference in the calipers you will probably need to do them as well. The NB8B brakes are one of the best mods I have done. The difference in braking is enormous.
Jumping back on topic I decided to go with EBC Red stuff pads on the front and EBC Greens stuff pads on the back. Just finished breaking them in so I will keep it updated as to how they go. Ended up costing me about $400 all up.
Ben
