NC powar!
JBT
Postby JBT » Fri Jul 20, 2007 5:42 pm
The standard NC puts down about 87 rwkw and weighs about the same as an NA8. Gearing probably also has something to do with it. I agree with the torque spread thoughts - my butt dyno tells me the NC is like a V6 compared to our previous NA8. :)
stevesports
Postby stevesports » Fri Jul 20, 2007 8:11 pm
Okibi wrote:
Charlie Brown wrote:...In the dry the difference is that I'm braking later and getting out of the corners quicker and therefore carrying more speed down the straight....
I thought it "Slow In - Fast Out" was the better method?
it really depends on the corner. In certain corners fast in slow out might be the better method, or might produce similar results.
Although generally slow in fast out would produce faster times.
irwin83r
Postby irwin83r » Mon Aug 06, 2007 11:28 pm
JBT wrote:The standard NC puts down about 87 rwkw and weighs about the same as an NA8. Gearing probably also has something to do with it. I agree with the torque spread thoughts - my butt dyno tells me the NC is like a V6 compared to our previous NA8. :)
so it is a bit ahead of the nb's in straight line speed then?
