Help.... Oil Filter!!!
- Garry
Unless it's been put on by a gorilla or you own an SP and the AC pipes stop you getting access from above and I cant get my arms in the right spot for enough leverage through the mudguard. I use the tool on a loooong extension arm. It's still a PITA but I cant do it any other way. I've tried lots of times.
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
mx_adam wrote:Don't know about anyone else's cars - but on mine there is an aluminium support that goes from the underside of the inlet manifold to just below where the oil filter is. Its basically impossible to get the filter on or off with it in place. Fortunately just 2 bolts to undo to get it out of the way........... then filter change as normal!
Standard brace on the NA series' - never found it got in the way until I installed the oil feed fitting plate to feed the turbo..... I just sourced a different sized filter in the correct fitting size.....
- Sean
Uncle Arthur wrote:mx_adam wrote:Don't know about anyone else's cars - but on mine there is an aluminium support that goes from the underside of the inlet manifold to just below where the oil filter is. Its basically impossible to get the filter on or off with it in place. Fortunately just 2 bolts to undo to get it out of the way........... then filter change as normal!
I've removed the support from 3 NAs and never had an issue...
Makes the car lighter too
