Slipping clutch - need help/advice
ampz
Postby ampz » Wed Nov 29, 2006 10:15 am
If you are doing the clutch yourself (to save $$) get someone to machine the flywheel. This give the new clutch a perfect mating surface, which will reduce the possibility of clutch shudder and gives the clutch plate the best bedding in period for longevity.
Only about $40.
Huh?
StanTheMan
Postby StanTheMan » Wed Nov 29, 2006 8:09 pm
192k km thats with a few track days as well.
but i'd expect the clutch to last between 150-180k km.
Thats sensible but spirited driving, no clutch dumps, or chirps .....and crap like that. :mrgreen:
Andy Wana
Postby Andy Wana » Mon Dec 04, 2006 12:17 am
Guys and girls, I need some help/suggestion with my NA
Last Saturday, the car's beginning to make these very unhealthy noises everytime I step on the clutch to get into 1st gear and 'reverse'
It's sorta like grinding and dragging ...
It's done 122K and it's been religiously serviced
I don't push hard or thrash it in any way
I fear for my car's health :cry:
Maybe a new clutch assembly is in order?
I ♥ asymmetry
JBT
Postby JBT » Mon Dec 04, 2006 6:39 am
Very hard to diagnose without hearing/feeling it. Does it only happen when you depress the clutch pedal when stationary or does it make the noise as the clutch starts to engage? Doesn't sound like clutch slip though. :?
Could be the spigot/input shaft pilot bearing or the throw out/clutch release bearing. At worst it could be a gearbox problem. :(
In any case, it seems that the engine or gearbox will have to come out to get to the affected area. Might as well replace the clutch while you're there.
Andy Wana
Postby Andy Wana » Mon Dec 04, 2006 7:34 pm
JBT wrote:Very hard to diagnose without hearing/feeling it. Does it only happen when you depress the clutch pedal when stationary or does it make the noise as the clutch starts to engage? Doesn't sound like clutch slip though. :?
Looks like I am getting a new clutch assembly done ($$$) this week. :frown:
The prognosis by the auto technician wasn't good, but it is probably due to wear and tear.
Any suggestion as to which parts are good to replace the factory clutch/flywheel/thruster/etc (you get the idea)
Being a newbie, I only know Exedy like those fellas in The Fast and the Furious knows NOS
I ♥ asymmetry
