Just a thought...
I have had brake lines made up before out of mild steel tube (modifications on old holdens)
Would it be overkill to make an oil line from mild steel for this purpose (with a threaded collar on a bell end sort of thing) routing it via the firewall?
I have however used braided lines on other turbos and never had a problem.
The fixed line would look more like a factory setup (in my eyes anyway)
Project Boost - BSDD Style
- ampz
- Vehicle: NA6 - Turbo
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Just went and bought the remaining hose, joiner, and clamps to hook up the boost gauge - just to get some baselines, and because it is there......
IT WORKS A TREAT!!!!! Interesting to see that under no load and cruise, intake vacuum is around 10PSI, spiking to 25-30 when backing off. Under full load, intake pressure is sitting at just under nothing, so I can't wait to see the difference when she's running 9PSI
- sabretooth
- Vehicle: NA8 - Turbo
- lowmiata
Uncle Arthur wrote:sabretooth wrote:Why run the oil feed line from there? That's going to result in a pretty long feed line as you run it around the block to the turbo itself.
Running it from there actually at the suggestion of LowMiata...
If you are taking oil from the filter pickup, it
- has been filtered (good for turbo)
- is at max pressure (guaranteed flow)
- is easy to access (not like the hose pickup behind the exhaust.
A long oil line isn't a problem in my books - and it can be easily routed along the firewall - away from heat generation areas.
nanana you miss understood me
my oil line comes of where the presure sender comes out of the block
not the oil filter
another 100mm and aft alittle and you will find the oil presure sender
I only got it from there as I could buy all the parts from AVO that did it that way
EVI15 1998 to 2008
- Uncle Arthur
not the oil filter
nanananana - I did understand - I knew that yours taps off the oil pressure, but I can't find a fitting that will work with the oil temp sender and still keep the opil feed and pressure - that's where having that one plate comes in.
And I had the numbers off the boost gauge wrong (typed them from memory) - idle is 20. 'Peak' is around 25 on full vacuum, and WOT is at around 2 in.Hg.
- sabretooth
I think you have to also watch where on the filter mount you grab gets the oil for those outlets from, as from what I can tell from a diagram I saw on solomiata (it's in the workshop manual) the oil is filtered and pushed into the centre.
Found it - here's the pic: http://members.aol.com/solomiata2/miataoilsystem.jpg
- Uncle Arthur
