Leaky..... :(
JBT
Postby JBT » Mon Jun 19, 2006 11:42 am
Uncle Arthur wrote:Second - what's the recommended way to remove and to replace the crank seal?
I think the popular way is along the lines of: drill two small holes in the seal. Put screws in the holes and then use a puller attached to the screws.
Attacking it with a screwdriver may result in a damaged crankshaft :( . Are you still sure it needs to be replaced?
http://www.aus-cartalk.com/viewtopic.php?t=18145&highlight=
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Mon Jun 19, 2006 12:44 pm
Uncle Arthur wrote:Speaking of tools to do the job - Sabre - do you have the DIY or other tool to use to hold the crank in place while reattaching the crank bolt?
What year is yours?
I just used the 5th gear and handbrake method.
While the timing belt is still on, get some liquid paper and mark a bunch of reference points. Then you can transpose them to the new belt.
Drill as JBT said. Just one hole should do - and you shouldn't need a puller - just pull on the screw. I'd still do it; it sucks to have a leaky car, plus Mazda service will do it every 100 000 and I trust their judgement.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Mon Jun 19, 2006 1:02 pm
What year is yours?
I've currently got the old belt still attached to the pulleys, held with bulldog clips. I was concerned that even with 5th and handbrake, I might still turn the crank away from TDC (against the efforts of compression). I can transpose the marks, but apparently there's another way where you slide the new belt on and clip it, before removing the old one.
Drill as JBT said. Just one hole should do - and you shouldn't need a puller - just pull on the screw. I'd still do it; it sucks to have a leaky car, plus Mazda service will do it every 100 000 and I trust their judgement.[/quote]
That's what I'm thinking, and going on all the effort to pull it apart once, I would hate to have to do it all again for the sake of a seal.
rhysk
Postby rhysk » Mon Jun 19, 2006 1:30 pm
Uncle Arthur wrote:I've currently got the old belt still attached to the pulleys, held with bulldog clips. I was concerned that even with 5th and handbrake, I might still turn the crank away from TDC (against the efforts of compression). I can transpose the marks, but apparently there's another way where you slide the new belt on and clip it, before removing the old one.
The crank will move while tightening the bolt, but when do you need to tighten the crank bolt? By that stage, the new belt should be on the car so no harm done. Mine is a 92 so maybe yours is different?
The 'cut the belt in half' trick won't work if you are touching the water pump or crank pulley. As scary as it seems, aligning the new belt is easy, but it is nice to have the marks so you don't even need to think.
sabretooth
Postby sabretooth » Mon Jun 19, 2006 2:33 pm
No DIY tool. I’m not a tool either. :)
What I do is put everything together, handbrake on and the car in fifth and yank on the ratchet hard. While the manuals might say 150-200ft.lbs (or whatever - my torque wrench doesn't even go that high), reality is that you don't need that much. I know I've got enough torque when the handbrake + 5th gear isn't stopping the car from moving forward.
What's the liquid paper and whatnot for? I remove the belt entirely and:
1) Rotate the crank to TDC
2) Rotate the cams to as close to TDC as possible
3) Put a shifter on the flats (where it’s designed for a spanner to go) of each camshaft and move the camshafts so that they are aligned with the blacking plate that says where I and E should go. The shifter handles must overlap each other to make an X. See 4 as to why.
4) Using a quick-release C clamp, clamp the shifters together.
5) Count the teeth between the notches on the top of the camshaft pulleys. If the count is not 19, redo the alignment until there are 19.
6) Back off the tensioner pulley bolt, and slide on the new timing belt. Pull the tensioner away from the belt a little and tighten the bolt just enough to keep the tensioner from putting much tension on the belt. It may be easier to put the belt around everything except the tensioner, and then put the belt around the tensioner last.
7) At this stage, everything should be at TDC. If not, fix it until it is. :)
8) You will notice that there is a "slack" part in the belt. We want to move this slackness so that it is where the tensioner is. So, put your ratchet on the crank bolt and rotate it slowly. The slackness will move around until it is where the tensioner is – it’ll probably not even take a 1/4 turn. So, once the slack has been moved, release the bolt on the tensioner to let it push on the belt. Now do up the tensioner’s bolt to the correct torque.
9) For sanity’s sake, give the crank a few rotations until the cams are back at TDC. Count the teeth, check that no part is overly slack, and you’re done.
jules
Guitar Hero
Postby jules » Mon Jun 19, 2006 2:54 pm
Yep, I'm up for it Mikey. Have told the wife I have a prior engagement!
So, what time at your place? Actually I might just check my mobile :D :D
Are you sure you don't want to do the cam seals at the same time??
Jules
Uncle Arthur
Postby Uncle Arthur » Mon Jun 19, 2006 3:17 pm
jules wrote:Yep, I'm up for it Mikey. Have told the wife I have a prior engagement!
Jules
Sabre - I reworded that bit about the right tool for the job few times inmy head, but figured you'd know what I did and didn't mean :D
Jules - How does 10am at my place sound?
Sabre - Are you still OK for a dodgy day at my place next weekend?
JBT - do you wish to join us at your leisure on saturday afternoon?
Hegzie - might you also drop around to make some noise? :D
JBT
Postby JBT » Mon Jun 19, 2006 3:22 pm
Uncle Arthur wrote:JBT - do you wish to join us at your leisure on saturday afternoon?
Yep, can do - about 12:30pm. You still at the same place where we did the slave cylinder? PM or email your phone number.
Is it recommended to get a new crankshaft bolt rather than use the old one?
What to bring?
Uncle Arthur
Postby Uncle Arthur » Mon Jun 19, 2006 3:49 pm
What to bring?
JBT - 12:30 is fine. There is no recommendation in my manuals to replace crank bolt - and it is unmarked from its removal. I have all the necessary tools now, so no need as far as I can think to bring anything. We're probably doing Jules' timing belt too, so there'll be plenty to do.
I'm no longer at Newmarket - now at Fairfield (between Annerley and Yeronga). I'll PM you the address. It's up the hill towards the railway line, with a big mango tree in the front yard and a gravel driveway - but of course the MX5's in the driveway will be a solid giveaway too. :)
jules
Guitar Hero
Postby jules » Mon Jun 19, 2006 3:59 pm
Oh, I might look at getting some parts then!
Jules
Uncle Arthur
Postby Uncle Arthur » Mon Jun 19, 2006 4:02 pm
jules wrote:Oh, I might look at getting some parts then!
Jules
Or are we??? I got the impression yours was nearing the point of needing it done(????) so I raised it as part of the day's activities.
Parts are radily available from Repco.
JBT
Postby JBT » Mon Jun 19, 2006 4:30 pm
No probs mate. I just thought I remembered reading on the U.S. forum that it was good idea to replace it because the old bolt approaches plastic deformation on a re-install and can lead to the dreaded crankshaft nose damage problem.
Uncle Arthur
Postby Uncle Arthur » Mon Jun 19, 2006 4:33 pm
Might be an issue on the short nose - from the looks mine is the long nose.
jules
Guitar Hero
Postby jules » Mon Jun 19, 2006 5:31 pm
I was just going to have a good look at the change done first hand before deciding whether to do mine or give it to Mazda :mrgreen:
Jules
PS: I have heard that the Mazda genuine water pump is the only way to go.
AJ
Postby AJ » Mon Jun 19, 2006 5:36 pm
What to bring?
oh....not far from us either.............might drop in for a look & give unneeded advice & sh!tstir jules Unca A.......if that's ok of course :mrgreen:
XMX5 Rogues
